Question about Frigidaire ATF6000ES Front Load Washer
When you start the washing machine after 5minutes off
Remove motor controller (in the bottom of case) look at circuit board,chances are its been wet.you can solder jumper wires across the bad spots.this fixed mine saved me $$$
Posted on Jul 12, 2009
Zanussi aquacycle 1200 want open
H? there
This somerimes happens t? my Candy, then I d? the same ?s you.
I also turn to off, wait the desired two minues> turn to empty, most often she does as she is told> turn off, wait the two minutes> turn to spin, turn off> wait the two minutes. This usually works and then I can put on any program. This works for me. Hope you find a solution for you,
kolbrun
Feb 04, 2015 | Zanussi Washing Machines
My xqg50-9 door wont open even though nothing in drum.
Is it disconnected from the mains supply and been left for 5minutes before trying the door?
Dec 18, 2014 | Washing Machines
My toyota harrier 1999 doesnt gear up, sometimes i have to restart it so ican drive normally like 5minutes,,when i fully push the gas pedal it makes a ramming sound and it stutters
you are not in USA, so post country.
the harrier here is Lexus RX.
so not posting that , nor posting what engine is in car makes
all answers wrong.
generic answers.
1: get a tune up, (the operators guide has a list. the 60,000 mile (100km) column are the critical parts. as is any cam belt.
May 04, 2014 | Cars & Trucks
Why does my lg washing machine dissplay CL on it and i cant turn power on
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again. Hope this helps... Please post back if you need more information.
Dec 11, 2010 | Washing Machines
Washing machine comes up flashing with a de sign
LG machines with DE (Drain Error) Water has not drained enough in 5minutes...Probably due to a partially blocked pump filter....Repeat drain to empty machine and cleat pump filter,,,Access via small door at floor level, unscrew pump cover, and clear filter... Some water may be released. Leaning machine back can help!...Good luck..Nomess
May 17, 2010 | Washing Machines
Our Fisher & Paykel Smartdrive LO8 washer has been working great until yesterday. When going through it's cycle it kept pausing when expelling the water. When it got to filling or agitating it operated...
Try a rinse cycle 12 minutes only to see if it does that. If it is a case then the is some clogs up at the drain path. Need to remove the bottom plate with a lot of holes to clean up. Good Luck.
Jan 02, 2010 | Washing Machines
Keeps flashing F35, when unplugged and plugged back in flashes SUD, there is no soap in the machine. When trying to raise / spin or drain or any other cycle keep getting F35 flashing. This is a Kenmore...
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Hotpoint wf000 on/off light flashing
empty everything out of the washer put it on the max heat which will be 90degree whites leave for about 5minutes to heat up place your hand on the glass door if the glass doesnt feel hot then your thermostats need replacing they r at the front under the front panel which needs all taking off is it emptying properly if not then the pump maybe blocked or faulty if it does then does the spin cycle work fast if not then u need to unplug the washer take lid off there will be a wire giong ti either sid of the motor these wires goto the carbon brushes ull need bent nosed pliers to take them out the ends of the pliers need to go down either side of the carbon brush squeeze and pull out these should have at least 8ml left of carbon these start of at about 1in in length they will need replacing
Aug 26, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
