Question about Canon PIXMA MX850 Multifunction Printer
When I duplex in landscape mode the text points indiferent directions. How can I change this? For example - one side is upside down.
In page setup, in the Duplex section, check Duplex and Automatic, and then select Short-side stapling (Right). I had the same problem, and this solution worked for me.
Posted on Jun 07, 2010
HP P2015dn when printing booklet, double side print, the print on the back of all pages are upside down. How do I fix it
Many duplex printers have an automatic setting for booklet print. If not, you have an option in the printer settings for long side or short side flip. If you are printing an A5 booklet (ie A4 folded) the setting should be landscape, two pages per sheet, flipped short side.
Nov 04, 2017 | HP Office Equipment & Supplies
2 sided printing in a4 landscape mode prints upside down when viewed by flipping page over
Check your duplex settings, should have option of long side or short side flipping.
Dec 28, 2014 | Office Equipment & Supplies
I am trying to duplex print a document in MS Publisher, landscape orientation. I've gone through all the regular set-up, even using the wizard. No matter what configuration I use, the backside of the page...
Try setting every other page so that it is upside down. It is what I have done when feeding something through the copy function and I wanted it to end up double sided, so it should work in your document as well.
Feb 05, 2011 | Brother MFC-9840CDW Laser Printer
My book fold booklet is printing upside down when duplexed!
You may need to tell word you want your printer to flip on the short side and not the long side. With my Canon printer I get a drop down menu IN WORD (not printer setup) that gives choice of: print one side; print two side flip on long; and print two sides flip on short.
Jun 02, 2010 | Microsoft Office Word 2007 Upgrade Version...
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
Canon DR-9080C Duplex Rotation issue
Scan in portrait mode only. Of course this takes more time as compared to Landscape mode. The top module 'reads' left to right as we see it and the botom module 'reads' right to left, if you look from top. So if you scan in landscape mode and rotate, the back side is rotated by another 90 degrees and hence you see it upside down. If you are using PDF file and have Adobe Acrobat, you can specifically rotate odd or even pages.
S. Mohan, Chennai, India
Jun 23, 2009 | Xerox DocuMate 252 Path-Through Scanner
Do not know how to print two-sided documents in landscape mode.
This one is easy but it will take trial and error before it will work. You need to copy one side then take the same copy and put it back in drawer. Trial and error come from you making the 2nd side to see what side and direction to put paper back into the paper tray to get it correct. Hope I did not confuse you. Let me know if this helped or fixed your issue.
Mar 12, 2009 | Office Equipment & Supplies
Canon MP610 Printer When automatic duplex printing in landscape orientation, the reverse side is printed upside down. Duplex Printing in portrait mode works fine. Can you help?
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Oct 27, 2008 | Canon Office Equipment & Supplies
Sharp arm355N/fx/srg
When you select double sided printing in the printing options, there are two choices--book mode or tablet mode. I think you want book mode.
Aug 28, 2008 | Sharp AL-1655CS Laser Printer
MP610 How do I duplex print. I have had every second page print upside down. o I manually turn the page over/
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Jul 17, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MX850 Multifunction Printer Logo
175 people viewed this question
Clive
Clive
old marine
old marine
