Question about IBM Computers & Internet
How to repair the ejector lever of ultrabase x3
How to open my ultrabase x3 thinkpad x31 to repair the ejector lever, it does not work ,the latch seem to have disengage
  • 611 Answers
SOURCE: Opening the hood on a 1994 buick leSabre
sometimes you can see the bolts hold the latch on and remove then with a 10 mm socket
Posted on Jun 16, 2008
SOURCE: dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
bmw_tech_38
  • 113 Answers
SOURCE: Hood Won't Open, and Lever Broke
Hi viper852004 , the only way you can do this is to remove the front grills and then you will be able to see the 2 sprung bonnet pegs, you will need to loosen the adjusting nut where it screws into the hood and unscrew it until it becomes unattatched from the hood, do this for both pegs and then you should be able to release the hood to fix the problem. the pegs will need to be reinstalled before driving the car as the hood will not close, hope this is of some help, regards mark.
Posted on Jan 26, 2009
  • 13 Answers
SOURCE: my laptop ( IBM thinkpad x31) won't turn on
GO 2 CONTROLL PANNEL .DEVICE MANERGER .MICE AND OTHER POINTING DEVICES ,RGT CLICK PROPERTIES CHECK C IF THE DRIVERS WORKING ? HAVE FUN !!!!!!!!!!!!
Posted on Feb 20, 2009
SOURCE: Volvo v70 1999 tailgate won't open
I had the same problem on my '98 V70 - my rear liftgate would not open. The "rear lift door open light" was on. I guess it was some kind of electronic problem in the locking mechanism. But it could have been something else like the metal bar that extends from the outside handle down to the mechanism had slipped off (unusual design seems like it should be connected instead of just sitting on a plastic latch handle) or maybe it was bent because this car had been hit in the rear as I found out looking around in there. Anyway, I took off the interior panel and inside handle. There was a large torx bolt that had to be removed if I was going to replace the mechanism. I later found out that there were two more once I got the gate open. I took a photo of the way everything was connected so I would have a record just in case I needed it. I bought a new lock mechanism. There is a thin piece of plastic down near the bottom on the mechanism that somewhat blocks a screwdriver or other tool from reaching in and opening the door that way. So I had to start removing things. I disconnected the power first. I removed the two screws I could reach which let the part that was connected to the connector be removed out of the way. I removed the metal bars that went from the outside door handle and the lock down to the mechanism. I still couldn't reach where I needed to. So since I had the part I began to slowly break away pieces from the mechanism. They are plastic so they broke off without much trouble but it did take a little work. Finally I reached down to the thin plastic part I referred to earlier that covers the part that unlocks your liftgate and pulled it enough off of it to get access to the release. One last try with a screwdriver let me push the actual release and the door opened! There was much rejoicing. Then I removed the old and replaced with the new. Reconnected everything checked and rechecked. It's working so far. That's how I did it.
Posted on Jun 14, 2009
Cant remove ibm thinkpad x31 from docking station
Press the "release" button/lever, to allow the ThinkPad to be "unlocked" and released from the docking station.
Jan 27, 2011 | IBM ThinkPad X31 Notebook
Not able to read dvd's and able to read cd's model lenovo 510i (what is it?) T510i Thinkpad?
While I was not able to find that specific model of laptop, I was able to locate the CDRW Bay and based on my research this bay only supports the following models. Though it may look the same and even have the same interface, if it is not in the supported model list, it will not properly function.
Supported Media Types:
  • CD-ROM
  • CD-R
  • CD-RW
  • DVD-ROM
Compatible with:
  • IBM Lenovo ThinkPad R50
  • IBM Lenovo ThinkPad R50e
  • IBM Lenovo ThinkPad R50p
  • IBM Lenovo ThinkPad R51
  • IBM Lenovo ThinkPad R51e
  • IBM Lenovo ThinkPad R52
  • IBM Lenovo ThinkPad T40
  • IBM Lenovo ThinkPad T40p
  • IBM Lenovo ThinkPad T41
  • IBM Lenovo ThinkPad T41p
  • IBM Lenovo ThinkPad T42
  • IBM Lenovo ThinkPad T42p
  • IBM Lenovo ThinkPad T43
  • IBM Lenovo ThinkPad T43p
  • IBM Lenovo ThinkPad T60
  • IBM Lenovo ThinkPad T60p
  • IBM Lenovo ThinkPad X40 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad X41 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad T30, X30, X31, R40 series (2366, 2367, 2884, 2885, 2681, 2682, 2683, 2896, 2722, 2723, 2724, 2897, 2672, 2673 - when installed with the optional ThinkPad Slim Drive adapter for the UltraBay 2000 or X series UltraBase or Media Slice)
If you see your model in this list comment back and we can move forward with getting your issue resolved.
Good Luck,
NOLA Tech
Jan 29, 2010 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
I have an IBM X31 Thinkpad It powers up and the fan runs but the screen will not operate and I cannot seem to get it to power up.Is there anything I can do myself before I have to scrap it or take it to...
there should be a fitting on that for an external monitor. hook it up to it to see if it works on that. also examine the keys on the keyboard. one should look like a small monitor. generally you tap that key and the function key at the same time to toggle from external to internal monitor. try that first. i wouldn't suggest throwing it out at all. if this is not a solution. post that someone if not myself will offer more advice
Nov 22, 2009 | IBM ThinkPad X31 2672 Notebook
IBM ThinkPad 560X UltraBase
Look at the bottom for the type (ex:570E is type 2464) but it looks like Thinkpads 380 & 385 are compatible
Mar 11, 2009 | IBM XSERIES 235 HOT-SWAP PSU CONVERSION...
My laptop ( IBM thinkpad x31) won't turn on
Feb 20, 2009 | IBM ThinkPad X31 2672 Notebook
IBM thinkpad x31 w/ultrabay 2000 blu-ray drive question
If the bay is a DVD drive Blue Ray will work as long as you have a newer DVD decoding software. There are some decoders or codecs at IBM's support site, such as WinVid. If the codecs at IBM do not work with Blue Ray, then try download.com and search for DVD playing software.
Aug 04, 2008 | IBM ThinkPad X31 2672 Notebook
Computers & Internet Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
