Question about Refrigerators
Where is the water filter located in my kenmore model number 25350682000 refridgerator?
  • 864 Answers
Upper right back corner of the refrigerator compartment.
Here is the manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802218.pdf
Posted on Jul 11, 2009
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Cannot locate water filter for my kenmore Refridgerator 106-57562792
Yes the filter is only available on some models. This is noted in the manual next to the part description: Part 14 Water Filter (on some models).
The entire set of parts lists (including a replacement grill plate, if you want it) is available from Sears Parts Direct: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657562792/0582/0165000?pathTaken=&prst=0&shdMod=10657562792 . The grill plate is part 13 on the cabinet diagram.
I hope this helps.
Sep 04, 2012 | Refrigerators
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
25350682000 stopped cooling and freezing
With the limited information that you are providing, it is impossible to give you good advice. If your compressor is coming on (and fan is operating) then I would check for ice build up on the evaporator coils in the freezer. If the compressor is not coming on then I would check out the start relay and capacitor. Items 30 and 55 on the following schematic.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-25350682000/0582/0165000/P0080147/00006?blt=06&prst=0&shdMod=25350682000
Jan 13, 2012 | Refrigerators
5the bottom part of the kenmore refridgerator drips water because the vegetable trays get filled with water and water is on the glass shelves. I have temperature on the normal setting. Model 106 I think,...
You have a clogged drain. Drain is located in the freezer behind the back wall. Can defrost with a hairdryer or turn unit off for approximately 4 hours to defrost.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Kenmore Refrigerators
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
Refridgerator
did you check the resevoir in the fresh food section it may be frozen. There is also a possibility that this refrigerator has a dual valve one sends water to the ice maker the other to the water dispenser it may be bad. I tried to look it up but the model number listed would not come up I think you are missing numbers best to get a complete model number from the refrigerator not the manual.
Jan 01, 2009 | Kenmore 54362 / 54364 / 54369 Side by Side...
Need a water filter
part number 9010-- substuted over to part number 4396510, says its the right part
Nov 18, 2008 | Refrigerators
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
