Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Convergence generator Was told today that the DCU/convergence generator was bad in my TV.  Was also told it would cost around $600 to fix with the board being $250.  I sent the tech on his way with no scheduled return.  I've been hunting far and wide for this part with no avail.  Anyone know where I can find this?  Or offer any recommendation.  Thanks
  • Papa_Gue Nov 15, 2007
    The picture is just extremely wavy. The Red gun was also turned up very high but the guy fixed that. My wife said that when the tech touched something in back then turned the TV back on that the wavy lines went away but then came back. I talked to him on the phone and he told me that I needed a new convergence generator.
    My original problem was getting it off craigslist ;) I didn't pay much for the set but I'd really like to not spend $600 fixing the thing.
  • 143 Answers
What was your first problem withe the set the original problem
Posted on Nov 15, 2007
The TV has a problem with the convergence? how much will this cost me to fix?
Call around all tv shops to get the best prices.Tell them u are 100% sure ur tv have convergence board problems,no examine and problems estamate require,just give u the final priced to fixed the tv convergence board.The prices awhile back $300-350 for complete tv convergence board fixed plus parts too.
Jan 05, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Sony KP-65WS500 from 10/2002. There are thin red arcing lines across the screen when the scene is dark or black.
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Red color is out of adjustment
The convergence circuit on these sets uses a digital correction signal sent through amplifiers (also known as convergence ICs) to electronically correct the convergence. If you can adjust the convergence with the remote and everything moves as it should then it is likely not the convergence ICs at fault. It is likely the digital convergence unit (DCU) that is not storing your setting. If you find one of the colors won't adjust or move properly to your satisfaction then it is likely one of the convergence ICs and possibly some resistors as well that need changing.
This is not really a DIY project.
May 23, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Convergance Issue...
You can call in a shop or do it yourself. Average repair bill from a shop will range between 300 - 600. Average DIY cost will be 70.00
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | JVC AV-56WP30 56" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Colors drop- similar to convergence problem
no i think he is taking u for a ride. u just need convergence ic and what happins is sometimes tv service centers will use sup replacemeet parts in stead of original parts u need to replace the convergenc ic whit original parts.and if they donot put heat grease on the convergence ics and that is y they go out again. but i have never seen the digital convergance unit go bad. and this problem can be repaird in your home for 200. - 250.oo at the most marty
Oct 13, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Samsung pcj522r
Its the digital convergence unit. If that goes out you will not have any control over the convergence. I have seen many times where the convergence ICs were suspected to be bad, and then after changing the ICs the set still wouldnt converge. the magic focus is controlled by the DCU often the magic focus will work only part way, then other times it will go farther then back to nothing. The DCU is usually suspect if more then 1 color is out.
Jul 26, 2008 | Televison & Video
Resetting convergence daily on Toshiba 43h70
Hi Mark, tough call without putting a scope to the circuit, either the convergence IC`s are going bad, signal from DCU is going bad (digital convergence unit), or possibly bad solder somewhere in the convergence circuit, I`m afraid your going to need a tv tech for that problem, BMW Rider
Jan 02, 2008 | Toshiba 43H70 43" Rear Projection...
Convergance circuit board
you don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Wavy picture
@unclejed ahem, what convergence module please?? the set has only one module and that is the DCU. so you have one in the shop,yes? are you sure you know what you are doing? by your description you don't and just get the real technicians out of work. do you think that is fair to rob us of work we need to make a living??
Aug 22, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
