These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device; here it is "Panasonic Plasma TV", in the search box [at the top right] of the display window. It will make surf easy.
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
SOURCE: black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
SOURCE: I have a Philips 50 inch plasma tv. The light is
I have Philips 50 inch plasma TV purchased almost exactly 3 years ago. Completely out of warranty. Paid 1999 bucks for it new. Now Plasma TVs similar to this are 800 bucks. I figured the cost of a repair tech coming to the house would be around 500 bucks.. so I decided I could "do no harm" and look at the power supply. Sure enough, two 3300 uF caps were swollen.. I am far from a true electrical repair person, and if it were not for the caps being swollen, would have no idea that they were bad. I am however a little bit skilled in soldering. So I ordered replacements for about 8 bucks. The caps were actually only 1.50 ea. but the min order fee and shipping brought it to about 8 bucks.. I got them from studiosoundelectronics.com . They came in today and installed them... to my astonishment, my TV works as good as it did when it was new... I must say that I am dissapointed in Philips.. and will never buy another product from them. If it is out of warranty.. they will not even talk to you.. I don't think it is too much to ask when you spend 1999 bucks on a product from them.. I expected my TV to have more than 2.999 years in life in it. Thanks a million to this site for providing soulutions for folks..
Jeff
Florence AL
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
