Will not start there is no juice going from the battery to the engine at all the lights will not turn on or the horn won't blow nothing works at all
did you changed the battery ? and then it did not start, how do you know that it is fully charged.
well lets assume that you are right, get a test light, start by putting one end to the battery positive +, the other end touch the engine block, valve cover what ever is metal on the engine, if comes on you are ok is far is the battery, then if ok, open the fuse box next to the battery and look for a main fuse, 80 or 100 amp, if you cant see inside, or you cant pock it, pullet out, ground one leg on the body any were, and touch the other leg with the test light, if it light up is ok, if you can pocket, the test light mast light up when you hook up the test light alligator to ground. and continue testing all the big fuses, also look at the battery + terminal may have a little box on top with 1 or 2 fuses, main fuses, check them the same way, both side of the fuse must lit up, if one side does not lit up, you have a open main fuse. good luck.
