Question about Sony Ericsson w580i Cellular Phone
Back button doesn't work
Okay first it was only the colored light on the left side of the phone - it got stuck on green
which i didn't really care about, then the top part of the back button stopped working.. I was like okay, I learned to live without it
BUT NOW the bottom part doesn't work either, how am I suppose to use this phone without a freaking back button? uggh if I squeeze it and push really hard all at the same time it works but only SOMETIMES.
also, months back like half the keys all cracked, again, I didn't really care because the phone was still useable & the camera sometimes goes green? you have to squeeze around where the lens is to get it to go back to normal. uggh now I gotta buy a new phone, i'm sad because I loved this phone I jus wish it didn't break so easy ? WTF sony...?
Im having the exact same problem right now. i'm looking for a do-it-yourself method to fix this ASAP! someone help?
Posted on Aug 09, 2009
Sim card slot stuck
1) taken apart and rebuilt cellphones and 2) dealt with hundreds of malfunctioning phones that didn't read SIM's, I'll give you some ACTUAL help.
1) remove the SIM and check for any missing pins in the slot. You can only see the first row of pins on the N1, but that's all you can see without taking the thing apart again. You should see 4 pins, but the one closest to the notched corner of the SIM doesn't really do anything.
2) If everything looks okay, reinsert the SIM, along with a couple pieces of paper. The idea is to press the SIM into the contacts in case the fit isn't as tight as before.
If you either see damaged pins in step 1 or step 2 didn't work, take it back to the repair guy. He broke it, he's obligated to fix it.
Auto Accessories
May 24, 2012 | HTC TyTN II Smartphone
No brake lights on 1985 chevy silverado 1/2 ton
Make sure your dash lights are working. If not then the headlight switch needs to be replaced. If this is okay go to the back of the truck under the rear bumper on the driver's side and you should see a plug where the tail light harness plugs into the body wire harness. Check this carefully for corrosion ( green gunk) and broken wires. Over time this plug usually corrodes up and wires rot off. I always cut it out and spliced the wires together with heat shrink tubing and tape.
The light sockets ground to the box behind the lens so make sure the black wire has bare shiny metal to metal contact on both sides of the box. The sockets themselves could also be worn enough so as to not make proper contact. Also check the wire harness at the light for chaffing and bad insulation. If I had a nickel for every time I had to fix this....... I kept a roll of tape in the truck at all times.
If you still have nothing, then you will likely have to follow the body harness back to the fuse block looking for the same thing, chaffing or broken wires. You can remove it by undoing the 5/16 bolt in the center of the block and pulling off the left side. All wires to the back of the truck are on this plug.
If you still have nothing then check under the dash. Trace the wires from the brake light switch to the wires from the blinkers. They both use the same side of the bulb. Dark green and yellow if I remember right.
If you have the floor mounted dimmer switch, check the plug in for it very carefully for corrosion. I'm pretty sure your wires go through it too, not sure why. Hope this helps.
Feb 22, 2012 | 1985 Chevrolet Chevy
I just got a used lg env2 and for sum reason i cant dial out it says press ok key to unlock but nothing happens when i press the ok button. it still shows lock symbol in red color on the left of the front...
Have you tried pressing "Okay" then "Clear"? I know there is two lock features on it, and one is a double button lock. If that doesn't work there could be something wrong with the front keypad. Flip the phone open and see if it lets you unlock it that way.
Nov 02, 2011 | Verizon Communications enV2 Cellular Phone
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
I recently replace the battery in my 2005 Ford Mustang GT. After I installed the new battery the green light for my dealer installed alarm keeps flashing even when I am driving the car. I went to the...
                Hi
                Before Battery Change
                • When was/or when did you notice alarm green light illuminated?
                • When after alarm was disarmed, did green light shine?
                First thing to check would be electrical connections starting from the battery.
                1. Follow positive wire lead from battery to fuse box connections. (Should be along driver side frame rail, or near battery.)
                2. Follow wrie harness to Relay Center. (Find Alarm Relay/Fuse)
                3. Also to Power Distribution Center. (upper driver corner engine bay)
                Relay Switch and Fuse to Alarm should be okay, given the alarm green light illumination.
                The Cars Brain, ECM Engine Control Module, manages messeges between power BattV and Alarm, also other modules and various sensors throughout the vehicle.
                When Battery Supply was disconnected, something happened, that stunned the memory in the ECM.
                Yes, the alarm does need resetting, its actually the memory messages saved in ECM need to be Refreshed.
                (saying "alarm needs resetting") sounds like alarm is broken, when that is not the case. Similar scenario is, when smart phone screen webpage freezes(alarm memory info in ECU). No buttons work, not even power button (Key Fob control). Only way to gain access is to remove battery.
                Lets try an experiment, this will be to loose still/saved frozen information, stuck in computer memory.
                How to Reset Vehicle Computer.
                1. Remove Neggative Post connection.
                2. Remove Positive Post connection.
                3. Let vehicle sit over Two Minutes, this time allows capacitors in vehicle Modules (ECM/PCM, TCM), to release any/all stored voltage, also any voltage in Vehicles ground circuit will be released.
                  • (I would typically wait 15 minutes) Capacitors with out constant Voltage input, will disipate rather quickly, depending on capacity size.
                4. With Battery Still Disconnected. Open Driver Car door, and turn Ignition to RUN Position.
                5. Reconnect Positive Post.
                6. Reconnect Negative Post.
                  • IGNITION is in RUN Position, when reconnecting Battery. Driver Door Is Open.
                  7. Turn Ignition to Off.
                  • Notice if alarm green light is illuminated.
                  8. Hit LOCK Button On Driver Door Switch to Reinitialize Alarm.
                  • Be SURE Key Fob not locked in car.
Mar 26, 2017 | 2005 Ford Mustang
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
Pictures are coming out green
It seems like the previous owner messed with the color effect feature on this phone. After you take the picture and its under your picture file, you can edit it. view the picture and go to options. scroll down to image editor and clikc okay. click on tools (right hand side). scroll down to color effects and click okay. now you have a menu where you can change the coloring of the picture. You may want to try the enhance green feature first and make sure its not set completely to the +5. The default settings have red, green and blue all set at zero. Hope this helps!!
KC
Oct 26, 2008 | LG Shine KE970 Cellular Phone
I hav a sonyericsson w580i and my right button, walkman, and applications button does not work -
The w580's sometimes get a short in a bend in the upper switch flex. It needs to be replaced. I'd bet that the lights on the right and left side of those outer buttons are different colors. Try applying light pressure just below the LCD screen and see if it brings those buttons back. If it does, that flex is bad and needs to be replaced.
Contact www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited. They can take care of that a lot cheaper than sony ericsson can. If you can find the part on line, you have to completely disassemble the phone from the back through the front to get to that flex. Switch Flex for Sony Ericsson w580i.
Jul 31, 2008 | Sony Ericsson Cell Phones
Sharp arc 262
Open the Left side door and remove the fuser unit by unscrewing the large green wheel located under the frame on the left side door below the fuser unit. Lift the fuser unit using the handles front and rear sides. (be careful it is very hot). Set the fuser unit on a table or counter or desk. Look carefully at the left side, as it sits in the machine, near the middle. You should see a actuator for a sensor. Make sure both ends of the arm are in the holes where they shoud be. If it is out of place, put it back into place and carefully place the fuser unit back in the machine. Secure the fuser back in the left door and close the door.
May 27, 2008 | Sharp AR-BC260 Color Copier
Flashing pot and pan light
shut off the power and see if the unit will reset. if its plugged in, it will be easy, look under the sink. if not, try a breaker.
let the power stay off for about a minute.
then back on.
if not restored, then you have logic boards that failed.
sorry,
good luck
mark
Oct 24, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Sony Ericsson w580i Cellular Phone Logo
107 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
