Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive eco Iw811 Rinse 1 no water coming thru!
The washing machine fills and washes fine but when it comes to the 1st rinse, it is not coming thru with any water, it will continue onto the 2nd rinse and that one is fine. When it comes to the spin cycle that works but the machine hesitates for awhile. Please I'm hoping someone can help me.
Thanks
Nikki
  • Carlos Simpson May 11, 2010
    Please check to see if your first rinse light is flashing during your first rinse cycle.
  • 27 Answers
The 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Posted on Sep 23, 2008
Fault code 49 ...any one can help me what is happening my machine.???..
Posted on Apr 28, 2012
  • 4 Answers
Neil V
We know that this is what its supposed to do but it doesn't. Spray rinse doesn't happen at all. The cycle limps on with many long pauses till the end.
Posted on Mar 07, 2010
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Hi, Having trouble with initial fill model IW811, will work some days and not others. Say's" I am not getting any hot water" so I tip 2 buckets of hot water in and it prompts it to continue...
Hi Maree just read your posting.Sounds like a fault I had on an intuitive washing machine the other day.To repair that machine I 1st changed the hot water valve then eventually had to change the control module.Is your machine the 'Intuitive model'?Is the machine beeping and showing an error code in the led display? Please reply with additional information and I am sure I can help.Looking forward to your reply.
May 23, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washing machine fills very slowly even though there is plenty of water supply. Sometimes the water only dribbles in. The worse time is on nthe rinse 2 cycle. Now it stops when the machine gets to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Fisher and Paykel (IWL12)
Warning I have too many suds
Hi just read your posting.Now just a couple of questions.1st where is the machine draining the water to?Is it into the laundry sink or to another place?Have you removed the clothes from the machine?Have you tried putting a bucket or two of water manually into the bowl and put it to a spin cycle to drain the water out? Please reply with additional information and I can help you further.
Jul 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My machine will fill & go thru a wash cycle but wont rinse or spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Feb 08, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Machine cant get any water.
Does the water fill to the correct level ?
Sep 09, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
882 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
