Question about Dell Dimension 4600 PC Desktop
Filmstrips My mom is having a problem with her Dell Dimension 4600 computer. When she boots it up, the monitor display has lines and what she tells me looks like 'filmstrips' of different colors that sometimes move and sometimes do not. They are pretty much blocking the view of everything on the desktop. We troubleshooted the monitor on two other computers and the monitor works fine. Can anyone tell me what this issue is? Is this a video card thing or what?? Thanks a lot for any assistance you can provide!
  • 1,601 Answers
Sounds like a corrupted video driver.
Have her do a system restore.
Then get an updated driver off Dells Support pages..
Posted on Nov 15, 2007
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
Acer flat panel monitor with dell dimension 4600 desktop, i am having a resolution problem. Icons are blurry, or fuzzy. the computer does not have a DVI port to connect to the monitor. I have used only VGA...
the issue is most likely the resolution you set the panel to. also make sure you select a generic flat panel driver under the Display properties EXP: if your panel is a 17" Panel chosse 1a driver with a max resolution of 1024X768 @ 60hz to start and go on from there you will solve it.. let me know if you need more help.. Marcelo
Aug 06, 2011 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4600 monitor has gone completely black though it shows it booting.
Start your computer in "Safe Mode".
Change the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, and restart.
If you eventually see your "wallpaper", try setting your screen-resolution to 1024 by 768, and "test" it. If OK, try setting your screen-resolution to 1280 by 1024, and 'test" it.
Jan 07, 2010 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600 Dimension Computer
are you getting the DELL logo screen.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
81 people viewed this question
Alun Cox
