Question about Creative Labs Audio Players & Recorders
The pin of my headset bend and now it works only half the time, any hints on how to fix it?
    Problem Solver:
  • 18 Answers
This is not easy to fix as the connector is usually molded plastic. If you have access to a soldering iron of low wattage (25W) and a small tip you might be able to replace the complete cord all the way to the headphones. This type of job is not quick and wires have to be disconnected at the earpiece. Sorry.
Posted on Jul 11, 2009
2000 3.2 CONCORDE CHANGED WATER PUMP TIMING MOVED HOW TO FIX
I know on some dodge products the timing belt drives the water pump and has a hydraulic pin tensioner. Generally you will half to press the pin back in bleeding it with a press then lock it in place with a pin and keep it upright up to the reinstall. If this is the case your gonna half to retime your engine aligning all timing marks carefully to avoid bending any valves or damaging pistons and various other internal engine parts. Once they are aligned properly then reinstall the belt and then the hydraulic tensioner and release the pressure on the tensioner by removing the pin holding it down. If this is the kind of system you have genrally dodge recomends changing your belt along with the new water pump.
Sep 30, 2017 | Cars & Trucks
We have 2 GN 9120 headsets that needed battery replacement. We ordered some from Amazon & never could get them to work. They actually worked for a half day and then stopped working all together (never...
Blow gently on both the pins that sit up from the base and the hole the pins go into, if you have a soft brush, use that gently to clean.
check the pins are not bent or broken.
Aug 22, 2013 | GN Netcom GN 9120 Professional Headset
One side of my tritton headset wont work
it has a short in one side of the headset. as much as you hate to hear it, you have to contact Triton and either have it refurbished, or buy a new one. The good thing is, Triton tech support is pretty helpful and will be glad to assist you. But for future reference, use steel series. as long as you save the receipt, if one side ever goes out, they will either send you a new one free of charge, or half price.
Jun 25, 2012 | Radio Communications
My jack is bended... :( the 3.5 mm one. the one that already connected with the headphone. how do i fix it? do i need to go to a music shop? or i can fix it myself?
if you cant bend it back to place with plyers it will definately bend with heat from a blowtorch
if you cant fix it yourself then your screwed there are no shops that do such a thing
Feb 10, 2011 | Skull Candy Skullcrushers Headset
When i turn off the phone (nokia 6630) and i turn it on it says to put the city time location, the time and the date. the second problem is that the headset icon is shown when i havent connect the...
hi,
your headset interface (the gold pins beside charging pin ) is shorted...you may fix it by changing that interface with the help of an expert mobile technician..bur wait, before spending money ,lets try this solution that sometimes works ,insert a headset then unplugged it...try it up to 5 times until the headset icon will lost... one of the reason why is that shorted is because when we talk ,there is a moist that goes to the mic of our cellphone which is connected to headset interface..i hope it will help ,thanks for trusting fixya...
Jun 16, 2010 | Nokia 6630 Cellular Phone
Get my headset in link mode but my phone doesn't
From my experience to sync the BT with this headset, there is a problem with the headset. Sometimes if you carefully bend the mic wand (mouth piece) backwards with even pressure it will connect to the phone. Eventually this fix will not work any longer, but it is a temporary quick fix. I threw mine away and bought a better one with no moving parts. I hope this helps and good luck.
Oct 27, 2009 | Motorola Mobility H700 Wireless Headset
Palm Centro has a faulty headset jack. I can hear sound through the (Plantronics, wired) headset, but no one can hear me, neither through headset nor without a headset. Centro acts as if there's a...
i had this happen to me recently and found out whats wrong the phones kinda slow and thinks the headphones are still plugged in and if you take out the battery and put it back in it saves that you had somthing plugged in and dosent help. For some people they can fix this as easily as plugging the headset back in and pulling it out slowly but for me this didnt work so what i did is, i turned on pocket tunes and you souldnt hear anything and make sure your sound is turned on, then take a small pin and stick it in the headphone jack and wiggle it around untill you hear somthing and then quickley pull out the pin.
Hope this helps
Jul 09, 2009 | Sprint Centro Smartphone
Pin code roe my H350
i forgot the code to my motorola h350 headset and wondering if you could give me it
Feb 15, 2008 | Motorola Mobility H350 Wireless Headset
Samsung wep410
As Quoted from Arfur - see bold print if you are having problems. You don't need to unpair the other phone, it will unpair itself.:
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Jan 15, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Card Error?
i think you have broken or bended any of the pin inside the card slot, and that is creating problem. Try looking in the card slot you may find any of the connector pin broken or bended. Try straighten the pin cautiously and may your machine start working .
Aug 16, 2006 | Fuji FinePix S7000 Digital Camera
115 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
