Question about RIM BlackBerry Bold 9000 Smartphone
Bluetooth doesn't reconnect to Jaguar handsfree
Blackberry 8900 Curve. Each time I have to enter the pass key, has paired ok, have checked all settings.
I had this problem. When the display on the curve asks for the pass key down at the bottom there is an option "Don't ask this again", you need to check this option and it should then pair automatically each time.
Posted on Sep 28, 2009
PAIRING PARROT TO BLACKBERRY 9320
To pair your BB to parrot go to connections
check whether the Bluetooth is ONthe search for devicesand when the name of the system comes..pair with the device.
Thank You.
Dec 26, 2012 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I need my Blackberry Curve 8900 unlocked! I need the Network MEP code. Any Help?
You can get the Network unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Aug 09, 2011 | AT&T Cell Phones
Need the numeric pass key for the blueant s1 car bluetooth. i have a blackberry phone have already tryed 0000 and 1234 doesnt work
The pin code for is 0000, you need to put the device into pair mode prior to entering it in your bluetooth menu. To put the device into pair mode, with the S1 off hold the green button down until you see a red/blue flash. When see that flash, enter the pin code when prompted and it should work.
Rylan
Aug 27, 2010 | Blueant S1 Bluetooth Handsfree Car Kit
Trying to pair bluetooth SPH M300 to my Blackberry Curve 8900 and it is asking for a pass key??? Help!!!
ALL YOU HAVE TO DO IS USE THE INPUT CODE 1234 UNLESS YOU HAVE CHANGED YOUR CODE....BUT YOU CANT DO THAT ON MANY PHONES
Jan 22, 2010 | Samsung SPH-M300 Cellular Phone
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
Jul 24, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth doesn't reconnect to my Jaguar handsfree
This might solve your problem; go on your blackberry and check in your bluetooth device list for your Jag's handsfree once you've found check the properties of it make sure it says "yes" under the trusted option now if that doesn't work then you need to check in the same properties if "encryption" is enabled if not enable it and you might not have to manully enter it all the time now if it already says enable you could try to disable encryption just to see if that helps. If you have any more questions or more information on this situation just post back and I will gladly help you some more.
Cheers,
Kyle
Jul 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Pass key
pass key 0000
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
Jan 13, 2009 | Motorola Mobility H300 Wireless Headset
Blackberry & BlueAnt pairing
Go into the curve under options / bluetooth and press the dotted menu key in the middle for options then select options again and change "discoverable" to yes and try it again
Jan 07, 2009 | RIM BlackBerry 8700c Cellular Phone
RIM BlackBerry Bold 9000 Smartphone Logo
180 people viewed this question
Top RIM Cell Phones Experts
ismael castillo
George Etukudo
George Etukudo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
