Cars & Trucks Logo
Catherine Lorigan Posted on Jun 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the location of low side AC port - 2008 Saturn Vue Hybrid
Steve Butterworth
Level 3:
  • Master 938 Answers
  • Posted on Jun 18, 2015
Steve Butterworth
Master
Level 3:
Answers
938
Questions
Helped
240708
Points
3298
Search "low side ac port Saturn vue hybrid". I got a good few hits suggest you do the same. I don't know enough to help you further.
Location of low side a/c port 2003 lincoln ls v6
Todd, Low side A/C port, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2000 Lincoln LS AC Low pressure port Location
2005 Lincoln ls low pressure port
low side port 2003 lincoln ls v6 Google Search
2helpful
2answers
Location of ac low pressure port location 2004 chevorlet avalanch
Look back on the firewall for the two a/c lines. One is large and on is much smaller. The larger line is the low pressure line. Follow that line back to the compressor. The low pressure port will be on that line.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
2answers
Where is the low ac port on 1999 Mitsubishi gst
The charging port is in the low side AC line from the AC compressor on the engine, the low side line is the larger of the two lines coming from the AC compressor.
2helpful
Location of low side a/c service port
The low side port is located in the low pressure side of the AC system, this is the larger of the two lines comming from the compressor.
1helpful
Which port is my low side service port for my ac on a 1986 chrysler new yorker located
The low side port is the one that is on the larger of the two AC hoses from the AC compressor.
4helpful
I need to locate the low side ac port. air conditioner needs charge and i cannot locate the right port.
The easiest way to locate the low side charge port on any vehicle is to locate the A/C compressor, follow the "larger" of the two lines all the way back to the firewall. Some where along that line you will find the low side charge port.
Good luck.
Regards,
1helpful
2answers
Where is low pressure port located on 1999 acura
look for the large ac line/hose and follow it untill u come to the small service port this is wher u charge the small ac line/hose has the large port this is the high side
1helpful
I need help finding the low side connector for a/c recahrge can you tell me location
2.4L engine AC low side charge port is located near the right shock tower. 3.4-3.1 engines AC low side charge port.remove right tire on driver side.remove splash shield.
12helpful
2answers
Ac low side service port location
Your service port will always be in the larger line of the two .. which is low pressure side. It might be in the dryer also which is low side.. your dryer is about 3 inches across and 8 inches long and also has your pressure switch for the AC compressor in it.. holler if you dont find it now... thanks Jerry
10helpful
Location of low side ac port
the low side charging port is near the AC Accumulator/Reciever dryer cannister in the larger of the 2 AC lines.
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
