Question about Sunglo Black Portable Liquid Propane Gas Patio Heater
Sun Glow solar panel system and require a replacement roof sensor
Hi I have an older pool solar panel system that I have upgraded with sunglo panels. I am still using the sun Glo 200 control box. My problem is the sensor on the roof. It only works some times? Where an I find a compatable one? I have taken it apart and it appears at first glance that it is a resistor or a thermistor? THere are no markings on the black box. Thanks
    Top Expert:
  • Sunglo Master
  • 8,889 Answers
Check for wire with exposed copper in wind maybe inaccurate or bad temp sensor
Posted on Jan 06, 2018
2 Suggested Answers
SOURCE: Leaking sunglo solar pool panels
I used to work at Sunglo. I am not sure how to repair but i can tell you how the panels were made. This may help you determine how to repair.
Each panel is made up of indivdual strips that have been extruded. The indivual strips are joined together to form the panel. Each strip has approx 8 or 10 internal and independent channels to facilitate the water flow. If one of these is leaking you should be able to repair with by sealing the hole with heat. If you seal the top part of the panel nothing will flow through to the bottom.
Posted on Dec 08, 2009
Black water coming out of returns from solar panels on roof of my home. Panels are 15 years old and there was frost in San Diego the nite before it happened
How do solar hot water panels work? - Explain that Stuff
www.explainthatstuff.com/solar-hot-water-systems.html
Jun 2, 2015 - Photo of solar hot water panels on house roof. ... What if you cut the top and bottom off a plastic bottle and fitted pipes at each ... This is the technical name for the big black panel that sits on your roof. ... The heat is then passed into the hotwater tank, and the cooled water (or fluid) returns to the collector to ...
Solar water leak - YouTube? 1:46https://www.youtube.com/watch?v=WaWkzfs6bikMay 22, 2012 - Uploaded by EnovativeGroupLeaky solar system, enovative group investigates... ... Solar water leak ... Solar Water Heating Panel and ...Pool Solar Panel - A How to Fix - YouTube? 2:50https://www.youtube.com/watch?v=f_KzEsxQhbEJul 7, 2012 - Uploaded by Clive WoodrowEasy and cheap way to fix a leak in your pool solar panel. ... The pipe (to carry the water to and from the ...
Dec 21, 2015 | Solar Pool & Spa
Had my roof replace so had plumber remove solar panel and reinstall now the water does not circulate and the system just flashes
The two pipes that connected the pump system to the solar heater were probably capped and they should have been connected to cause normal water flow. I hope this helps.
Aug 21, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
Ssv2 automatic controller panel is flashing 99 unable to change temp
A broken or disconnected roof sensor cable or open circuit sensor
Nov 09, 2009 | Solar Heating System For Swimming Pools
Have a supreme Solar - Solar conroller for swimming pool. Roof indicator light is flashing and system wont turn on, (not even in manual mode) Pump working OK though. What does this mean
it sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
Nov 08, 2009 | Solar Heating System For Swimming Pools
Aug 20, 2009 | Sunglo Black Portable Liquid Propane Gas...
Solar disappeared from display
well the old man said it replace the solar sensor but not need to be on the roof just make sure it get sun rays sh is a secret.
Jun 28, 2009 | Jandy Aqualink Rs4 One Touch Control...
Fafco Solar Panel system - how to bypass sensor?
I would, put a quarter turn ball valve in the sensors place.
Apr 14, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Sunglo panels on roof leaking with hole how do i patch them
stuff with foam that grows then use roof sealant or RV roof self leveling sealant
Nov 20, 2017 | Sunglo Black Portable Liquid Propane Gas...
Sunglo Black Portable Liquid Propane Gas Patio Heater Logo
188 people viewed this question
Top Sunglo Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Sunglo Pool and Spa Expert? Answer questions, earn points and help others
