Question about RTO Atwood DSI-RV Water Heater-6 Gallon
I have a six gallon atwood and the tank is split can I just buy the tank?
  • 160 Answers
YES!!
Posted on Jan 09, 2010
Atwood gc10a-4e only producing luke warm water
make sure bypass on back isn't open or half open then see if mixing valve on shower or outside shower off if all ok possible bad temp sensor
Feb 19, 2013 | Atwood Mobile Products Atwood 10 Gallon...
Hot water tap creates an annoying noise in the mh. The noise is coming from the Atwood hot water heater. (2007 Coachmen Mirada).
Like a buzzing noise? Check valve where water lines connect at back will make a buzzing noise, if you only hear it when running hot water and not when running cold. Remove and replace it after shutting water off, and draining tank down. Be sure to shut off any hydro to electric element prior to draining.You can buy a replacement check valve, or just put a short 1/2" pipe nipple in there instead and reconnect your line, and refill it. noise should be gone .
Jun 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
HI I HAVE AN ATWOOD WATER HEATER MODEL NUMBER GC6AA-9E AND AS HARD AS I TRY, I CAN NOT GET AN ANWSER FOR THE RIGHT REPLACEMENT MODEL. THERE IS CONFUSEION ON WHAT WILL WORK. YOUR ASSISTENCE WILL BE...
By model number it tells me that you have Electric element, as well as gas with electronic ignition for the gas, is that correct?
Any 6 gallon Atwood will work, and if you want to have all the same features available, you simply order another 6 gal, with same features. If you decide to forget the electric element, and just go with gas and electronic ignition, they should be able to order you just that tank. You can even order a tank with manual ignition, and forget all the other options if you wanted to. Personally, if it's got hydro and electronic ignition for gas, I'd replace it with same, unless I have no access to hydro, and will never use that option. If all those options are working on yours, you can just replace the tank, rather than buy all those items new on a complete tank. Any 6 gal. Atwood will go in the hole, it just depends on what you decide you want. I don't understand what the confusion is about, but maybe I'm missing something here.
Oct 02, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Is the atwood g6a7 hot water tank interchangeable with the atwood g6a3 tank
If your replacing complete tank and front face, yes. If just replacing aluminum tank itself, take a look at front face and see if it has all the same holes for pressure relief valve, etc. Either 6 gallon tank will fit, it's usually the features that are different, such as electronic ignition, or one has gas and hydro operation, where other is gas only. Obviously the electronic ignition requires a 12 volt DC source for it to work, where just manual light does not, as well as 120 volt operation requires a hydro hook-up if you want to use that option of it.
Jun 25, 2010 | RTO Atwood Water Heater - 6 Gal LP
Where can I get a 6 gallon atwood tank?
Depending on how big the split is, we have in the past taken it to a welder who can weld aluminum, and had them repaired, but price for repair got as high as replacing, so we stopped that. If he's good and pressure tests it after at a reasonable price, maybe, otherwise buy new.
Feb 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
128 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
