Question about Hayward Navigator Pool Cleaner
Hi my navigator only turns to the left and after an hour or so the hose is all twisted up and it cant move
  • 990 Answers
This is probally in the gear box in the top of the unit. Most pool shops will rebuuild the cleaner for you for just the price of the parts or a small shop fee. They can check for any other problems at the same time.
Posted on Dec 11, 2009
I have three nav vacs and two pools. each pool has a working nav vac and I keep one for a spare. Pool #1- the vac started turning only to the left and in 15 minutes the hose was completely twisted...
This is a common problem with the Navigator. If you grab the part sticking out where the lead hose attaches to the unit, you should be able to turn it fairly easily with your hand. This is the swivel that is supposed to keep the hoses from getting twisted. When you take the unit apart, you will find a large gear plate with teeth that controls the swivel action. All it takes is one leaf or small rock to jam this plate solid and then there is no swivel action and the hose twists. Leslies should have know all about this.
Aug 22, 2011 | Hayward Navigator Pool Cleaner
New pool cleaner , pool hose just keeps twisting up have laid in sun, but as soon as connected back up it twists
Is the pool cleaners hose actually twisting in the pool or before you put it in? If it is twisting outside of the pool, it might still straighten out when you put it in the water. It it is twisting in the water, you might need to add some additional hose lengths to help it operate smoothly.
Feb 26, 2011 | Hayward Navigator Pool Cleaner
Hose gets twisted all of the time Have replaced almost everything
Try laying the hose out on the ground and stretching it out as straight as you can get it. Let if sit this way in the sun for several hours. You might have a warp in the hose material that is causing these tangles. Allowing it to sit stretched in the sun for several hours will help. Also, try readjusting your return lines. They could be interfering with the pool cleaners pattern and causing the cord to become tangled.
Aug 20, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: When I run my hayward cleaner the hose twists up a...
You have either a bad or stuck gear box or a loose or damaged a frame bearing. The gear box controls turning and the a frame controls propulsion, but one bad bearing will cause the cleaner to move more in one direction, causing the hose to coil. You can hold the cleaner under the water by the top of the hose, and it should turn in all directions within a few minutes. If it doesn't, then it is the gearbox. If it does, then likely a problem with the a frames.
May 16, 2010 | Hayward Navigator Pool Cleaner
Hayward navigator (Gunnite pool) does not move. If I hold by hose, in water, suspended above bottom, the unit does not turn. Hose in good shape , valves in correct position. previous to this it was...
you need to install a turbine kit with "a" frames. sounds like your bearings are bad either on the turbine, "a " frames, or both. A set of shoes would be a good idea as well.
Nov 18, 2009 | Hayward Navigator Pool Cleaner
I have exactly the same problem-Navigator only turns to the left
it sounds like it needs a turbine kit with a-frames, it's a common problem with this cleaner. you can expect to install a turbine kit every other season if not sooner. If the wings and shoes are good, check the bearings both on the turbine and the a-frames. If they're good, check steering valve. hope this helps...
Jul 19, 2009 | Hayward Navigator Pool Cleaner
Navigator hose cntinues to twist
I would recommend replacing the gearbox. That's what controls the turning so, if it's not turning correctly, that's the cause. It could also be the hoses. You could change the order of the hoses and that might help.
www.cpo2go.com
Feb 22, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Will Not Move
The problem is that you have too much play in your drivetrain. You will need to check for movement between the pod and the a-arm and then between the a-arm and turbine. It would also be a good idea to check the turbine bearings. Find the loose fitting, worn part and that is your problem. As far as it not twisting on the end of the hose; this is most likely caused by the screen on the back of the unit being obstructed by debris or the gearbox assembly being jammed by debris that got through the screen or is just worn out. If you have any mechanical abilty you shoud be able to do these repairs yourself with the help of a downloadabe exploded diagram. If not call a pool repairman the parts are not really that expensive compared to the cost of a new unit.
Jan 28, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
1,100 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
