Question about Home
I have a 1993 95 ? Jacuzzi whirlpool bath out door hot tub Model h240000 name Z145 / 345 every thing works BUT i have thermostat on high and for 2 days cant get it above 85 or 86 just took out the filter it was a littel durty if it dont heat up any more without filter what else could be the problem thanks rob
    Scholar:
  • 80 Answers
It sounds like the heater element is going bad. It is located in the steel tube below the control box inside the access panel. Unless you are qualified to replace the element, better call in a pro. You can touch this tube while running the spa and see if it get warm.
Posted on Aug 19, 2009
I just got an outdoor Jacuzzi, it's all there. I just need to know what more do I need to hook it up to have it working
Didn't it come with installation instructions?
There are a number of very important things.
A flat level pad for it to sit on.
Correct voltage and RCB to prevent electrocution. The installation must be to building code.
A hose to fill it.
Chemicals to kill bacteria pathogens, and used in the right amounts and tested each time you use it.
Have a look at some of these videos.. You can also Google
make model installation instructions.
http://www.bing.com/videos/search?q=jacuzzi+installation&FORM=HDRSC3
Strictly speaking, you probably have a Hot Tub rather than a Jacuzzi which is the trade name of a bathroom bath that has water jets.
http://www.bing.com/videos/search?q=hot%20tub%20installation&qs=n&form=QBVR&pq=hot%20tub%20installation&sc=8-20&sp=-1&sk=
jacuzzi installation Bing video
Jun 20, 2016 | Home
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
I have a jacuzzi whirlpool modelz145, h240000 it keeps running on low never shuts off this just happened never did this before? Bad control board?
Is this an outdoor hot tub?
If it is an outdoor hot tub...is it heating up or just running all the time?
Sep 21, 2014 | Jacuzzi Home
Need to purchase 2 front panels [white] for Luxura 530 jacuzzi whirlpool bath model N795 also, called skirts
Bath Panels can be very difficult to locate. I would check with your local Jacuzzi Showroom first.
If they are unable to locate the panels you need or they are no longer made then you should head over to Lowes or Home Depot to get a generic panel from one of them and you may need both panels replaced so they match.
rod
US parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 16, 2013 | Jacuzzi Home
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi - GFCI keep tripping prventing Jacuzzi from starting Jacuzzi Whirlpool Bath, model H240000
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
Mar 28, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Home Logo
451 people viewed this question
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
