Question about Karcher 2500 PSI Pressure Washer
ICAN TRUN ON
MY POWER WASHER IT SETING FOR YEAR I TRY TRUN IOT ON ICANT CAN SOME HELP ME
Help with my bklyn email and to create anew account
Facebook Customer Support:
Phone Number: 1-650-543-4800
Average Wait: 12 minutes - 24 hours, 7 days
http://gethuman.com/phone-number/Facebook/
Facebook Customer Phone Number Shortest Wait Best Support
IF YOU LIVE OUTSIDE THE USA CLICK ON LINK ABOVE AND THEN CLICK
ON CALL FREE VIA WEB.
Suggest trying a new browser like Firefox or Google Chrome
YOU CAN GET THEM INSTALLED AT THE LINK BELOW:
http://www.ninite.com
By the way their are over 27,000 unanswered Facebook questions
that need to be answered. If no one answers them I will attempt
to.
Jul 23, 2014 | Facebook Social Network
I start the machine and after 5 seconds give me the 116-324 error code
Thats called an exception error. One of 2 things. Either it needs a complete software upload, or the network control board, called the ESS board has failed.
You can try these steps
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
The last one IOT ESS NVM will clear all your netrowk settings.
May 07, 2011 | Xerox WorkCentre M-24 Color Copier
Before ican play dvd to my pc and ican play sound but now icant i dontknow what hapend
If you plug in headphones do you get sound?
Check the Sounds option in the control panel.
Look at the settings by clicking on speaker icon in the lower-right side of your screen.
May 05, 2011 | HP Audio Players & Recorders
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
arrwup.gif Spool Initialization
arrwup.gif HDD Initialization
arrwup.gif ESS NVM Initialization caution.gif CAUTION
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
When i trun the streeing seems to get hard to trun and sometimes then lock up for a sec...
check power steering operation at 3000 rpm, if it working properly, you need to replace yoru power steering pump. it is a very common problem on that year f150
Sep 06, 2010 | 2004 Ford F150
WASHER GOES INTO ERROR IT SAYS E 10 CAN'T FIND MANUAL
I have a problem with the washer when trun on the it take the water and then E11 pop up and then trun off can you tell me why it doing that
Jan 03, 2010 | Frigidaire ATF6000ES Front Load Washer
How do i set my cam vision from being blurry
icant assess my webcam ican see people but they cant see me
Nov 30, 2009 | Computers & Internet
Danby diplomat microwave
Try visiting danby.com they have PDFs of their manuals to download
Mar 20, 2008 | Microwave Ovens
Seting my ringtone
push the joy key towards left.then you saw detail option,click it.after clicking you saw[ calls:_______].click that to change the ring tone
Sep 03, 2007 | Motorola Mobility E770 Cellular Phone
Karcher 2500 PSI Pressure Washer Logo
59 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Tim Venetis
Are you a Karcher Garden Expert? Answer questions, earn points and help others
