SOURCE: 1997 ford thunderbird LX . Rear Wheels - Upper control arm bushings.
Hi...
I 'm a mechanic and have been Replaced the UPPER control Arm bushing on thunderbird.
And the Price for the Bushing is CHEAP..
You need only Replace the damaged parts, not all the ALL HARDWARE, They are wrong.
OK.. you can find on any Autoparts. for EXAMPLE Here is AUTOZONE.
with the Bushings that you need. just look..
http://www.autozone.com/N,14600794/shopping/partTypeResultSet.htm
I hope this help on your question..
Thank you for use fixya..
SOURCE: Lower Control Arm Bushing replacement
I just did this job on my 98 regal, and I own the service manuals also. The lower control arm bushing that usually goes, is the front one. The rear one doesn't usually go, it is horizontally mounted. The front one for some reason is vertical. The control arm must be removed, and put in a vise. The front bushings outer metal sleeve, must be driven out with a chisel. It comes out easily. The new bushing can be tapped in with a hammer. Hope this helps!
JOEVETTE
SOURCE: Are the upper control arm bushing pressed in or
pressed in but can be removed by cutting with a hacksaw in reverse so to speak ,remove blade and push through bush to cut out the metal casing then pull new ones through with a long bolt and socket
SOURCE: 2003 Dodge Durango clunking noise in front end can
With the information given this is not a sure solution. Questions that need to be asked is when does this happen, turning at slow speedm high speed, when hitting a pot hole etc? Since you have replaced a lot of things already, assuming you have NEW good quality parts so you did not replace bad parts with new bad parts i would definitelu check the pitman arm. This runs from the stering gear to the tierod. It can give you some good clunks while steering, especially at low speed when there is a lot of resistance. Check it by having someone turning the steering wheel when watchin/feeling it.
SOURCE: 2004 Nissan Quest front control arm bushing replacement.
Sorry guys not a solution but I too have an 04 Quest, which supposedly has worn controller arm bushings and Nissan says I need both controller arms replaced. For a total of $950!!! I was told that they need to replace the whole arm and cannot replace only the bushings. Now reading the posts on this site I find that to be untrue. Seems all I need to spend is anywhere from $25 to $35 per bushing.
