Question about Kenmore 63942 Dryer
Kenmore 80 series dryer.
The dryer gets warm and the drum turns, but there is a noise coming from the front left lower corner of the unit. It is a cyclic noise that happens about once per revolution of the drum. It is not a constant noise nor a grinding, squeak or scrapping noise. It's kind of a rattle but not a metallic rattle. Almost like a vibration of something.
I'm not overloading the dryer and the noise is present always while running but more apparent with th heavier the load.
  • buca8933 Jun 22, 2008
    my dryer turns, heats up a little bit but the clothes do not dry.
  • Anonymous Sep 08, 2008
    dryer gets warm but clothes dont dry.
  • 943 Answers
Thanks for the question The noise might seem like its from the front but theres nothing at the front Now at the back you have 2 drum kollers By the motor you have aidler pully most times the idler is the problem you can buy a repair kit that comes with all the parts you need to fix noise belt , 2 drum rollers and idler pulley .replace them all . Thanks for the question The appliance doc
Posted on Sep 11, 2008
The hub on the blower wheel is separated from the wheel. Replace the blower wheel. They are about $15 on eBay.
Posted on Jun 04, 2008
    Champion:
  • 249 Answers
True story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Posted on Dec 04, 2007
Kenmore 80 series dryer is making a loud screaching grinding noise what could be the problem
Kenmore (Sears) dryers are usually manufactured by Whirlpool. The rear of the drum rides on 2 lower rubber rollers that go bad with age. Those rollers may need replaced. There is also a felt seal strip attached to the rear of the drum that rides the back wall of the dryer that may need replaced. Can only tell for sure by disassembling the dryer and checking.
Jun 02, 2015 | Kenmore Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Kenmore 80 Series dryer's drum is making a thump
I would check all the screw's to make certain they are tight. That was my problem when mine was making noise. Look on the interior of the drum.
Jan 01, 2012 | Kenmore Dryers
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Nov 16, 2009 | Kenmore Dryers
I have a Kenmore 80 series dryer(118.72812101).
You may have something inside the workings of the dryer which has shorted out the heater coil. this could be the source of the noise as well. you need to remove the cabinet to access this, yet be careful as the drum will fall out on you in process. You can get a new coil from an appliance part store in your area. Take the dryer apart before buying this tho, so you don't waste your money on the off chance that this isn't the trouble. you will need make model and serial number from unit so they can match up the proper coil for you. Make note of how the belt is placed and routed for proper replacement when reassembling. Also make note of 'drum rollers' condition, as this could be some of the noise also.
Best to you, hope it works out
Joe
Aug 26, 2009 | Kenmore Dryers
Kenmore gas dryer series 80 not heating up--dryer revolves but no heat--guessing it's the ignitor--can't access-no lower panel to open tomroske@msn.com
small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
Jun 27, 2008 | Dryers
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Dec 08, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
2,016 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
