Question about Shuttle Socket370 AE22 (MBAE22) Motherboard
Manual Where can I get an installation manual for this board.  I can't get my monitor to work.
  • Dhafer Apr 12, 2008
    upgrade SDR up to 1 G
  • 31 Answers
I admit this one was a zinger... It was very difficult to track down the information you need as Shuttle has discontinued active support for that motherboard on its websites (all of them it seems).
I did find a site in Germany that had a link for the manual in PDF format but the link was dead, so I fired off an email to Shuttle and happily was told that all you need to do is send an email to
Explaining that you own the AE22 and that you need the manual in PDF format emailed to you. They will forward that on to the person who handles that and you should have your manual in a day or so!
Posted on Nov 15, 2007
Toshiba satellite c675 monitor light up but not displaying anything
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. you will need to aquire a toshiba manual for your laptop to help you fix these issues. here is the link for finding your manual Search
Aug 13, 2014 | Toshiba Satellite C675d-s7310 Amd E-480...
Need manual
Although most monitors come with installation guides, usually all that's needed is to connect the monitor the the video signal from your computer's video card or on board video and to connect the power cable. If you post your monitor's model, I could further help you with step by step instructions on how to get it working.
Oct 18, 2012 | Computers & Internet
Although LG1720B monitor is plug n play, i can't install it's driver from the CD, the monitor is not working properly with HP driver in Win XP SP3
if the monitor is plug & play & it is not working properly, there is problem with the main board of the monitor. access the main board by opening the back cover & look for odd shaped capacitors. if all are fine then you need to replace the main board.
Sep 26, 2011 | LG 1720B 17" LCD Monitor
My computer turns on but does not connect to the monitor. I tried two monitors and the same problem occurs.
Hi avia798,
Most likely your On-board graphics card, or Addin Graphics Card is not working.
Firstly, make sure the power cable on the monitor is well inserted...
If you use on-board Graphics - Reset your Bios by following the step by step instructions in the OEM manual of your motherboard - Usually setting some jumpers to the On & Off positions.
If an OLD Add-On card - make sure it is in full contact of the slot (You can clean the goldish contacts of the card with a normal pencil eraser if you want to) and try again. If still not working, your Card may need replacing. If it is a new card, and you have installed it for the first time, reset your BIOS and set back to on-board graphics - and update your BIOS (Refer to your instruction manual - Known as "flashing" the BIOS), and try again.
Good Luck :-)
* If you found this solution helpful, please rate accordingly.
Jun 08, 2011 | Computers & Internet
Hi, I bought my samsung 2333 syncmaster in the U.S. but moved to New Zealand where the voltage is 230, can I use the monitor with a converter plug or with a NZ compatible cord?
Samsung 2333 have switching power supply and it can work from 100-240VAC 50/60Hz with out any modification or adaptors. Feel free to use it in USA or New Zealand. You need only to arrange plug converter. Check specifications on Page 49 of 2333SW user's manual available on: Samsung SyncMaster 2333SW User Manual Your Monitor Initial Settings
Jun 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Adding a video card and get no output
Look in the motherboards manual for info about installing graphics cards, see if it needs jumpers. Plus make sure you plugged the monitors vga or dvi on the right place (VGA or DVI port ON the graphics card, NOT on the old vga port you used to plug your monitor before )
See if it works otherwise tell me..
Sep 14, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
HP W1907 Monitor
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Jan 03, 2009 | HP w1907 LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Monitor is not clear and no sound (win 98) pentium 2 board
Your problems sounds like you are missing the drivers, can you provide the model number of your motherboard.
or you can go to
and download the correct drivers for your motherboard
Dec 27, 2007 | Intel Motherboard
Shuttle Socket370 AE22 (MBAE22) Motherboard Logo
125 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
