I have a Sears/Coleman central air conditioner p/n BRHS0481CB. The line contactor does not engage on it's own. If I manually engage it, the AC works great. I am not getting 24volts to the coil of the contactor. All the wires check good for continuity. I know the control board may be fualty, but is there anything else I can check before replacing the board?
  • 331 Answers
Have you removed the board. there maybe a burnt trace that you can jumper with a wire. I have done this is the past.
I went tot sears and found your model with part numbers. the link is below
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=BRHS0481CB&productCategoryId=0904000&brandId=1804&modelName=HEAT-PUMP-BRHS-SERIES&diagramPageId=00001&documentId=10042856
alot of parts for this unit are discontinued by sears you maybe able to find online somewhere other than sears
hope this helps. I am sorry I can not be of more assistance but it seems you already have covered the basic troubleshooting that can be done on my side.
Posted on Jul 11, 2009
Coleman 2ton Basement air does not respond to thermostat but will turn on and run fine after 6 to 36 hours
Check contactor in condensor,if it looks good check refrigerant levels if you're EPA liscensed.
May 25, 2014 | Coleman Mach III Air Conditioner
Coleman central ac is not shutting down. Thermostat clicks off but compressor and fan keep running and cooling
This is either a stuck relay or contactor or the Tstat is bad.. Try shuting down the power to the unit and wait for about 3 munites and trun it back on .. if that does not clear it up My money is on a stuck contactor
Jul 15, 2011 | Heating & Cooling
A/C unit won't come on. I have 230 and 24 volts to unit but contractor won't engage. What could problem be?
Check the 24 volt coil on the contactor for continuity between the 2 wires. I suspect the coil is open. If you have 42 volts ac at the base of the contactor and it ain't pulled in then it is shot. I wrote a tip on this and posted a couple of videos here How it works: Central AC Contactor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 21, 2010 | Goodman CLQ36AR49 Air Conditioner
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Compressor does not run. On turning the AC on, the compressor does not run. The blower fan does though. Checking the relay panel, the relay for the compressor does not engerize. a temporary solution is to...
Hi, if you are energizing the contacts on the contactor, and the compressor runs, the thermostat is faulty. This is what energizes the contactor coil that you have. You need to check to see if you have voltage to the coil on the contactor. You need to replace the stat asap.
Sincerely,
Shastalaker7
Apr 16, 2010 | Coleman Mach 15 Air Conditioner
AC Compressor
Check your CONTACTOR - the black "block" where all the line wires connect. Sometimes they stick. It's a cheap part, although make sure you take a pic of the contactor with all the wires attached BEFORE you take the wires out to get a replacement.
Aug 02, 2008 | Heating & Cooling
AC CONTACTOR REPLACE
contactors are just a switch l is the power t is the load (check the coil voltage see that its the same) dan
Jul 17, 2008 | Ruud Central System Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Compressor on central unit wont kick on
you need to use a meter to ensure that you are getting control voltage from the xfrmr. Also check it at the coil side of the contactor if you feel comfortable doing this but be careful of the line voltage side. If you are getting power on the coil side of the contactor usually a 24v signal from the tstat from the area labeled y and the contactor is not pulling in most likely you will need to replace the contactor. If the contactor is pulling in verify the amp draw on the compressor with the tag.
Apr 28, 2008 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
