SOURCE: Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
SOURCE: How do I change the
Refer to page E-15 of the manual.
Press the Mode button on the calculator until the
To change the settings for the number of decimal places, press the Mode key a number of times until you reach the setup screen shown below.
F i x Sc i No r m
1 2 3
Press the 1 key to select Fixed number of decimals to display
Press the 3 key to specify 3 decimal places.
The calculator will display the word Fix to indicate the display mode has changed. NOTE: the calculations will be made using 12 digits but the result will be made displaying only 3 decimal places. If you are using this for school and are instructed to use 3 decimals places for the calculations, you will need to use the Shift Rnd button to do the internal rounding. This will be important if you are taking a statistical class and find your answers are not matching the correct ones.
Best of luck, Jim
Set the slider on top to 2 or add 2.
