Video issues Video won't light up, audio works, on all channels and inputs 42" plasma TV model z42px2da
  • thorsig May 06, 2008
    Hello
    I have a LG 42PX3RVB-ZA, there is no display only black screen, but all the audio is working and even if I turn on the DVD or VHS it is still the same, only audio on display in the screen.
  • currentamer May 10, 2008
    Mine actually lasted 18 months. Then the repair shop replaced the video board for $512 dollars.
    I hope it lasts longer than the original.
    Good luck with yours.
    Currentamer
    Problem Solver:
  • 6 Answers
On a Z42PX2DA this symptom is a possible Y Sustain board failure.
Posted on May 09, 2008
  • 3 Answers
Posted same response on the other Zenith issue...
I've owned this unit since Dec 2005. It appears there are two Video Amp boards Z & Y-SUS boards, that have failure problems.
After 10 months, my ZSUS board went out and was replaced under warranty. And... Just a month ago, the same problem occured again, so I've complained to Zenith (LG) and they are extending my warranty to repair the unit.
Posted on Dec 09, 2007
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
How to hook up cable without using a cable box
this is a monitor plasma tv and it will need some type of tuner to bring the cable channels down to the audio/video jacks or the composite video jacks(blue/red/green) you can use a cable ready vcr to input the video in tv jacks and hook up the cable in to your vcr rf input.
Sep 01, 2009 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
My 42 inch sylvania plasma tv does not have a coax connection, so how do i hook up my cable to the audio/video connection? i know there is an rf converter to transfer audio/video to coax but i really...
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Aug 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Ysus board
the mainboard, controls the audio, Tv Tuners, Vga , HDMI, S- Video inputs.
The Y sus or (Y-Mainboard ) Is used to control the Panel (LCD) Video, it has 2 buffers that contol h/v lines in upper & lower regions.
Apr 22, 2009 | Dell W4201C 42 in. Plasma HDTV
Picture went out
Try this to get more information that will help diagnose the extent of the problem:
get a powerfull flash light
turn the tv on in the dark and point the flashlight right at the face of the screen and look for video..
make sure you have an active input or good channel selected..
if you see video where the flash lights then your cold cathode flourescant backlight is not working and this repairable at a reasonable price
Apr 09, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
How to setup my VCR to record programs from my Panasonic 42 Inch HDTV Plasma TV?
TV doesnt matter, you need to list what kind of VCR your trying to program with.
if you are programming from cable, the cable box, box or not, should be ran thru VCR then VCR to TV.
to record. easiest.
if you are doing cable to tv to vcr. make sure that tv is in one of the AV spots, so when you select input on vcr itll show your tv again. program as accordingly.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
No video
try checking what your dvd is set on ie rgb pal or nstc, then check in your tv manual what inputs it accepts
Mar 25, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Aug 14, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Open Questions:
Televison & Video Logo
236 people viewed this question
Top Televison & Video Experts
