JVC 42'' plasma TV (PD-42WX84) screen turns grenn after 10 minutes
Turn TV on nice picture for about 10 minutes and then evrything turns green - turn TV off and wait for when Tv cools off and works fine for 10 minutes and screen turns grenn again?
branko6038@sbcglobal.net
    President:
  • 563 Answers
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Can jvc vm-42wx84 be used as a monitor without tuner
This is a screen with a media box. The box has two connections to the display panel. The first looks like a DVI connector. The second is the proprietory control port connection. This is how the set receives commands about brightness, contrast etc, scaling, aspect ratio. It might even control such basics as power on/off.
You could try the panel just with a DVI connection, but you will have to make sure that all sources are scaled to the panel's native resolution (1024x768) before they reach the screen. This is part of what the media box does. You might be okay if you're driving the panel direct from a PC graphics card. But if you want to run it with a variety of different sources then you really need to use the JVC media box.
I can't say if the Hitachi media box would work.
Sep 10, 2014 | JVC PD-42WX84 42 in. HD-Ready Plasma...
The picture has gone on my Samsung 50 inch plasma tv. I have sound only. Don't know if it's worthwhile getting it fixed or if I should buy a new one. It's only three years old.
Plasma tvs are tricky for picture. They use two boards to burn the plamsa gas instead of one (LCD)...This almost doubles the price for any replacement boards, unless you know componenet level repair.
Overall, if you can find someone that will work cheap and knows what they are doing...then yes it isn't the most intence repair...but if NOT...then it's probalby too expensive to buy the replacement baords.
Thank you!~
Jun 16, 2011 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Convergence is off, picture curves down from the top of screen.
yes the convergence ics are crooked ( big rectangular shaped mounted on heat-sink). you can order them online. check for any open resistors on the output pins.
Mar 25, 2009 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
Apr 07, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
42" Plasma Displays only Green Screen
dds426's reply:
The problem was not a cable connection. A chip needed to be replaced at the tune of over $600j (includes $200 for the repairmen coming to my home to dismantle and take to the shop and return it).
Jan 02, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
OPERATION MANUAL
hi any look from ths site with the manual http://retrevo.com/s/JVC-PD-42WX84-TVs-review-manual/id/279ci161/t/1-2/
riz.
Nov 18, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
Jvc AV42PD20ES 42INCH TV
Hello gladwin6,
You may have at least a blown fuse. However you may also have other damage to your power supply. This often happens due to the voltage spike caused by the power coming back on suddenly. You can check to see if the fuse is blown, however once you change the fuse and if this does not take care of the problem, I would suggest that if you do not have a background in electronics, that you have a qualified technician take a look at your TV set.
I hope this helps,
Thank you,
Shuttle83
Oct 24, 2007 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
