SOURCE: Cannot retrieve download information. Please connect to Itunes
Make sure that your ipod is synced with the right date and time then close itunes and restart it sync it and it should work
SOURCE: nokia 6120 is not sending sms it gives msg
Try going into message settings found in your messages. Then go into text messages and look for the command: "Reply via same centre" activate this to yes then try again.
SOURCE: my lg phone says im roaming when im not and it
Your phone is programmed with parameters to trancieve from a particular network. It roams when you're outside the coverage area or when the programming parameters have been altered in some way. Check your settings or refer to the network's programming unit to have the parameters entered correctly... then you'll be connected to the network services.
SOURCE: I have 8900 blackberry curve
It sounds like you have overridden the MMS settings provided by TMobile. Have they resent these settings to you? Save these as you did previously, and you should be able to carry on.
Check you have send via MMS option from a contact in your address book.
SOURCE: My E71 will not send messages. I can recieve sms,
got a brand new nokia e71 and i can recive messages but i cant send messages back! it says unable to send to (name)
