Check your battery...make sure she is tight and charged, make sure the bike is in neutral......been caught by that one...check the breather.....and replace the spark plug....sometimes they spark but are too weak when under compression
Carb could be dirty, float stuck or choke stuck. Pull plugs, crank engine and see if you are getting raw gas in the cylinder(s). If you don't get gas to the cylinders, you won't start. You also could have a flooded carburetor.
Testimonial: "I cleaned the carb nothing is stuck in it its getting gas to the cylinder and still wont start"
Almost
every vehicle needs regular servicing and repairs in order to
continually perform at its best, and Polaris' lineup of four wheelers is
no exception. The company has released dozens of ATV makes and models
throughout the years, ranging from sporty racing
quads to youth models to heavy-duty utility ATVs. Despite the
differences between the company's many makes and models, general repair
tips and troubleshooting instructions remain consistent for all Polaris
four-wheelers. The electrical, ignition and fuel systems are some of the
most common sources of Polaris ATV problems.
Read more: How to Repair a Polaris Four Wheeler ' eHow.com http://www.ehow.com/how_8074861_repair-polaris-four-wheeler.html#ixzz26pmQIzeh
Then check the air flow path to the cylinders from the air filter to the manifold. Make sure the filter/path isn't clogged.
