When off for awhile the tv will come on for a second and click off you have to click the on button for a long time before the tv is warm enough to stay on It is an LG flat screen about 3 years old
    President:
  • 563 Answers
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. If you purchased an extended service plan they will repair the TV at no charge.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
How do I unfreeze a samsung tv screen, NOT a smart tv
Try holding the power button down and with it still pushed in unplugging the unit for a few seconds then release the power and before you plug it back in hold the volume keys and power down at the same time and while holding plug it back in most tvs have a reset sequence hope this helps
Jul 28, 2018 | Samsung Computers & Internet
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Mitsubishi VS-55707 and I have a couple of problems. first it takes 5-10 minutes to warm up (scrambled picture) after that it works fine, but its getting longer to warm up. Second every once in...
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
May 23, 2010 | Mitsubishi VS-55707 TV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Sony Trinitron KV35V36 Blinks Every Second
Picture blinks on/off and audio is still there?? If so it's the crt and a common thing for sonys to go out like that.. You can lower the G2 voltage a bit and that might help for awhile or have the tube rejuvenated by a technician - but either idea is only a temporary fix...
Sorry
Bill
Dec 08, 2007 | Sony KV-32FV1 32" TV
Blinking picture
Common problem on older SONY = BAD CRT ....replace TV.
..........................................T.
Nov 30, 2007 | Sony KV-32S42 32" TV
Turning off PIP on KP-61v45
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
