I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
On the remote press the System Menu botton when opened, press Enter and scroll down to Option and press Enter then scroll down to Command, press enter and you'll find DVD1,DVD2 and DVD3 scroll down to it press Enter set or reset your unit as desired!
Pressione a tecla Enter e o nº 2 ao mesmo tempo por 3 segundos.Logo após começará afuncionar o System Menu, quando entrar novamente em opcções para escolher o DVD3 ,que é o default ,repita a função de 3 segundos com o enter e o nº 3 e assim começará a funcionar o System Menu com default 3 ativado. E na página 99 leia a NOTES para ativar a reprodução do DVD em(Y Cb Cr) de HDMI, passando o Progressive para offsua imágem ficará perfeita.
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Go to your DVR and manually turn the DVR off. Press the STOP button for two or three seconds. The DVR COMMAND MODE setting will display in the DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing both the remote ENTER key and the desired number key (1, 2 or 3) and holding them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE. To do this depress SYSTEM MENU on the remote and go to SETTINGS and then COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER key and the desired number key (1, 2 or 3) and holding them both at the same time for 3 seconds. The remote should now control the DVR.
To reset the factory details as if it was just removed from the box - Leave the recorder on, flip down the front panel on the recorder and then press and hold the channel up and down buttons at the same time until it says bye on the display. Wait a few seconds then turn it back on. It should automatically select all the programmes available
