Question about Garden
Replace the prewound spool in the toro electric trimmer 88005
My trimmer needs to have the prewound spool replaced and I cannot find the owner's manual - can you help me
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 28 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
radar001
  • 1051 Answers
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Posted on Apr 06, 2010
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
Does Toro still make 88035 spool cap replacements? I cannot find them anywhere.
According to this large online parts distributor, that part has been discontinued.
http://www.partstree.com/parts/?pn=88035
I found this one on Ebay....it looks like the spool with the knob for a 10" electric trimmer. I tried!
http://cgi.ebay.com/TORO-PREWOUND-SPOOL-ELECTRIC-TRIMMERS-PART-88180-/280505426528?pt=LH_DefaultDomain_0&hash=item414f6d2260
May 14, 2011 | Toro Electric Trimmer
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
Jun 29, 2010 | Toro Electric Trimmer
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
I can't remove the spool to replace the line. How
there is a button on the end of the shaft. it can be tight sometimes so a large pair of channel locks might help. turn the button counter-clockwise, and the pull the spool head off.
Aug 30, 2009 | Toro Garden
Jun 03, 2009 | Toro Electric Trimmer
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Garden Logo
269 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
