Sony hdd I have a sony hdd which when I was in Kl malaysia I had sony style put my 7 hours of video on dvd I come home and cannot open the files what do i do? I have a new pc best regards Laurie patmore
  • 37 Answers
The problem may be that the software on your new computer cannot play the video files.
  1. If you can tell me your operating system (windows XP or Vista?)
  2. the type of DVD videos you have?
  3. exactly how you made the DVDs - type of computer, software you used (sony style?) or did you use a standalone dvd recorder recording from the TV?
You can try downloading this free video player, which plays many types of video:
http://www.videolan.org/vlc/
Posted on Nov 15, 2007
Tip
Burning DVD using AVS Video Converter
Introduction
AVS Video Converter helps burning DVD to playback in your home DVD player from all modern video formats. The integrated DVD burning engine and the widest range of supported video formats make AVS Video Converter a perfect tool to create personal DVD videos. Just follow these few steps listed below.
Step 1: Download and install AVS Video Converter
Click here to download it. After the download is finished, run the AVSVideoConverter.exe file and follow the installation wizard instructions.
Step 2: Run AVS Video Converter and select your input video file
To select a video you would like to convert hit the Browse... button next to the Input File Name field. In the opened Windows Explorer window browse for the necessary video file:
Note: when your input is a DVD disc, you will need to select the path to your source file: X:\Video_TS\Video_TS.IFO. "X" stands for your DVD-ROM or the hard disk drive folder where your DVD is stored. Please see the online help section to find more on burning DVDs to other video formats.
Step 3: Set up the conversion parameters
Click the To DVD button on the main panel. In the list of video disc types (Profile) select one of the preset profiles.
You can edit the files for burning dvd. By clicking the (+/-) buttons you can add or remove files from the list. Using the Arrows you can change the sequence of files.
Step 4: Set up a proper video output file path
Click the Browse... button next to the Output File Name field and select a location on your HDD for the output video file.
Note: when you select a location for your output video file, you should save the file to your personal computer HDD.
Step 5: Create a menu for burning DVD
In case you convert your files into a DVD format, the program will let you create a DVD menu so that you could navigate through your disc easily using it. First of all you need to put the markers indicating the beginning of the chapters of your DVD menu. To do it switch into the editing mode using the Edit button on the AVS Video Converter main panel. The following window will be opened:
To add markers place the mouse cursor within the Timeline where a chapter should start and click the Add button located at the Markers Panel.
If you want to delete some markers select the necessary one clicking it with the mouse. Then use the Remove button from the Markers Panel or right click this marker and select Remove from the express menu. To delete all markers use the Clear All button.
After all the markers are added click the Ok button to save the changes you have made and close the Edit Input File(s) window. After that you can start editing your DVD Menu.
Click the Menu button on the AVS Video Converter main panel.
Switch to the main menu or a chapter tab and select one of the style presets for your menu or assign your own picture by clicking the Change Background button.
You can move the marker by dragging it along the Timeline, add a new one or delete them using the appropriate button.
After you add all the chapters and when you are satisfied with the result, close the Menu Editor window and start converting your video.
Step 6: Convert your DVD files
After you have set up all the conversion parameters, hit the Convert Now! button to start conversion.
When process is over the following window will appear, where you should click Burn to Disc...: for burning dvd
Step 7: Burning DVD onto a disc
Insert a blank DVD into your computer optical disc drive. Make sure that the disc is compatible with your drive.
You can select the necessary disc drive if you have several, refresh it and mark the Verify disc check-box to make sure the disc is recorded correctly.
Now click the Start burning! button to begin the recording. Note, that if the disc is not empty you will be offered to erase it. If you do not want to do that, you can eject the disc and use another one instead.
After the burning dvd is over the disc will be ejected automatically. Note, if you checked the Verify disc, the recording will take a little longer depending on the size of the output files as the program will need time to verify them.
Now you can watch your recorded home video DVD on your Home DVD Player!
How to create an Audio CD using CD Burner dvd? helps you to creat an Audio CD.
on Feb 07, 2010 | Computers & Internet
Tip
How to burn MTS, M2TS Videos to DVD on Windows 7?
You have .mts/m2ts videos on your HD camcorder and want to burn it to the DVD disk? This tutorial will show you how to burn MTS/M2TS Videos to DVD on Windows 7.
Before we go to step-by-step guide, we need to understand a bit of background knowledge about MTS/M2TS. According to Wikipedia, both MTS and M2TS are Sony high definition video file types, which are raw AVCHD videos recorded by AVCHD camcorders such as Sony HDR-SR1 camcorders. And m2ts files usually record onto 8cm mini DVDS or blue-ray DVDS, SD memory cards and Memory Stick, or record onto hard drive camcorder
So, We have to convert MTS/M2TS videos to DVD video formats (MPEG-2)before we burn it to DVD disk. Fortunately, there is Wondershare DVD Converter Ultimate can burn mts/m2ts video to DVD directly. Importing your MTS/M2TS videos into it and insert a blank DVD disk to DVD Rom, with 1 click, it will bring you a DVD that is playable on your home DVD player. Sounds great? Let's go to the step-by-step guide:
How to burn MTS/M2TS videos to DVD
Step1 Download Wondershare DVD Converter Ultimate, install it and running
Step2 loading videos
Load video files that you want to burn into DVD disk.
Step3 Making a DVD menu
You can select DVD menu template on the left bar. Set background image and music from you local hard disk. Then, click "Next" button
Name DVD label and set video quality and DVD disk type. Click "Start" button. Then, you can take cup of coffee and waiting until it done.
Step4 Burn DVD
That is it, 4 steps to burn videos to DVD and enjoy it on your home DVD player.
on Dec 29, 2009 | Cameras
I am trying to make a dvd from a HDD video cam to a sony DVDirect recorder VRD-MC3 and a message saying non supported USB devbice keeps comiong up. Can you hellp?
The manual of the DVD doesn't say much for models, say's sony HDD, sony DVD, so maybe it's not compatible. Do you have a memory stick for the handycam ? If you stored the video on the internal storage, check the manual to see if you can move it to the memory stick, then put the stick into the DVD player. Or you will need a PC to transfer it with USB, then get a memory stick and put all the video on in and not internal storage, if the DVD is not compatible with the handycam.
Mar 30, 2013 | Sony DVDirect VRD-MC3 DVD Recorder
I have a DVDR3450H dvd Recorder and it cannot open when i open there is a 'philips' sign on the lcd and do nothing after some seconds it seems it restarts with the philips sign again but doesnt work.. i...
Pull out the hdd and format it in a computer in one single partition NTFS. Put the hdd back and upgrade with the last file disponible on Philips and enjoy again your device. Success.
Jun 13, 2010 | Philips DVDR3450H DVD Recorder/HDD...
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
How do i delete videos off imagemixer page
run the handycam utility CD and install the HDD Handycam Utility driver/software. Then put the camera on the base, plug it into your computer via the usb cable. Turn the camera on. Wait 5 seconds, then hit the button on the base. You will here your computer recognize the driver and ask you what to do with it. Close that. Then open the HDD Handycam Utility probram. It will prompt you to import the video/camera files. You will find a delete option there, too.
Aug 26, 2009 | Sony Handycam DCR-SR42 Camcorder
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
