Question about Acer Aspire 5100 Notebook
MY LAPTOP DO NOT RECOGNOCE DVD-RAM - Acer Aspire 5100 Notebook
How to replace CD?DVD IN A135-S4467
It's very easy. First turn the laptop off with the DVD bay open. You will have to unscrew the memory ram cover, and pull it.
Afterwards you take a look at the screw that's on the left of the ram's compartiment. See this picture:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/take-apart-laptop/toshiba-satellite-A135-02.jpg
If you look close to the ram compartment you will see a screw on the left side. Unscrew it and that's it. You will only have to pull the dvd rom firmly outside the laptop-you can pull it from the bay, that why I've told you to let it open.
Feb 04, 2011 | Toshiba Satelite A135-S4467 Notebook
Sir i am getting problem in booting from usb dvd ram because my installed combo drive is not working ,so how can i boot from usb dvd ram and laptop cmp is "amilo pro fujtshi siemens"
You have to go in BIOS and choose in menu to boot from USB device (USB HDD, USB FLOPPY, USB CD-ROM and other in menu). To go in BIOS you press DEL or F2 or another button who writes on the first screen after you turn on the laptop. Good luck.
Jan 31, 2011 | Fujitsu Siemens Amilo Pro V2040 Laptop...
My dvd-ram working fine with cd but when i put dvd-rw nothing happend!
In that case either the disk is an incompatible model (it happens - try another brand) or the dvd laser has died - in that case you must replace the entire dvd-ram unit.
Sep 06, 2010 | Lenovo 3000 Y410 Laptop
Loose label dvd-ram not possible run any dvd
If by that you mean that you put a dvd-ram with a loose label in your laptop and now it stopped reading every dvd you have tried, then i'm sorry to tell you that your optical unit is gone, it will have to be replaced.
Mar 09, 2010 | HP Pavilion dv6000z Notebook
My acer aspire3680 laptop dvd writer cannot read dvd. they read only cd's.i have Dvd Decoder but still cannot read dvd's. why? plz send me answer my email address- sham_ptl@rediffmail .com
I have also the problem of yours but i have the solution and i do it with my pc now it read DVD/CD
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 09, 2009 | Acer Computers & Internet
I cannot get a dvd to play, nor can eject it
I think you have CD RAM and DVD ROM i had also the problem of read dvd but i buy CD/DVD RAM Now my drive is working properly and successfully
Apr 17, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
Laptop wont turn on at all/ satellite A215-S7422 pc notebook
If you are trying to retrieve the DVD from inside a laptop that won't turn on, the easiest solution is ... a Paper Clip! Straighten one end of the paper clip and insert it into the small hole on the face of the DVD drive and the door will open.
Dec 28, 2008 | Toshiba Satellite A215-S7422 Notebook
My laptop freeze
what is your cpu, ram, dvd drive specs. it may be as simple as either adding more ram or upgrading the cpu, or updating the driver for your dvd burner
Jan 05, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
