I HAVE A RYOBI PBC 3046YB WHEN I WENT TO USE IT, IT DID NOT SEEM TO GET THE FULL SPEED AT THE HEAD IF YOU PUT THE HEAD ON THE GROUND IT WAS GOING ABOUT HAFT SPEED . IF YOU PUT A BIT MORE PRESSURE ON TH HEAD IT STOP TURNING.
SOURCE: cant get my ryobi pbc-3046ye brushcutter to start,
probley got a pin hole in one of plastic tubes
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
