Question about MTX T-Form 00-05 Ford Focus Black w 12" Sub Car Speaker
I got a 2001 ford focus and noticed when i brake my front lights come on can n e 1 help?
    Problem Solver:
  • 15 Answers
I had exact same problem.replace both your brake/tail bulbs on both sides of car.make sure new bulbs have twin metal connectors instead of single.the single bulb connector was my problem,when i broke the side lights came on and all 3 lights were on when i turned side lights on.this will sort your prob out.hope this helps.let us know how you get on
Posted on Aug 21, 2009
    Problem Solver:
  • 26 Answers
The common problems with all FORDS is they suffer with bad earthing. Try replacing the earth cable on your rear lights. If this fails it could be a faulty cable located in the relay box, but you should take it to a qualified auto electrician for the work to be carried out safely
Posted on Jul 11, 2009
Hi can anyone help me got this 1.6 2001 ford focus now then this is it the front aand back light wont come only one side thoughso pls help thanks by the way brake light works fine
check the bulbs/fuses they could be blown on that side also the multifunction switch that you use for the hi beams and wipers could be out on that side or you have a bad headlight switch or a broken wire on that side that's what to look for good luck stephen
Feb 15, 2015 | 2001 Ford Focus
Problems 1. My brake lights stays on while driving without hitting on the breaks, 2. Car wont switch off after removing the key until I let go of the brakes then the car switches off. 3 Everytime I hit...
Hi, has someone recently installed something in the car or otherwise messed with the wiring? If not, is your ABS light on? If not either, I would say your hazard switch has gone bad.
Aug 29, 2011 | 2001 Ford Focus
2001 Ford Focus... No park/tail/brake lights!
Headlights and brake lights will not come on with ign. switch off. The running lights should come on. Check fuses.
Sep 26, 2009 | 2001 Ford Focus
Rear blinkers and brake lights on 2001 ford focus not working
yes it sounds like the turn signal switch is defective, the brake lights go through that switch as well.
Sep 06, 2009 | 2000 Ford Focus
I have a 2004 Ford Focus estate and when I brake, my front lights come on (the rear brake lights also come on fine). Any ideas why this may be happening? I think this started following my MOT being...
check the bulbs.mine were changed and some genius put wrong bulb in and i had exact same problem as you.make sure tail/brake bulb has double steel connectors.my drivers side one had bulb with single connector,i put new bulbs in both sides and problem fixed.hope this helps mate
Aug 07, 2009 | 2000 Ford Focus
2001 ford focus brakelights not working
check the fuses, and bulbs first, if not that, i might be the switch
Jul 14, 2009 | 2001 Ford Focus
Ford focus brake lights stuck on when sidelights on
hi, i have sorted this problem on my 99 focus ghia.,check both your tail light bulbs.someone put the wrong bulb in and i had the exact same problems you described.the bulb for brake/tail light has two steel connecters and and all other bulbs have one.i put proper bulb in and the problem disappeared.now lights working perfect and sidelights dont come on now when i brake :)change both brake/tail bulbs on each side.1 euro will fix this problem.hope this helps.
Jun 01, 2009 | 2006 Ford Focus
MTX T-Form 00-05 Ford Focus Black w 12" Sub Car Speaker Logo
67 people viewed this question
Top MTX Car Audio & Video Experts
Mike Duncan
Mike Duncan
Philip Armitage
Marvin
Marvin
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
