Question about Electrolux Central Vacuum
Power unit suction problem
I Have an Electrolux system and I have no suction. I have followed a flow chart for troubleshooting and at the power unit with the pipe disconnected I have very little/no suction, but I do have a ton of exhaust
  • 1,673 Answers
Have you checked the filters?
Posted on Jan 29, 2008
My electrolux versatility vacuum doesn't have much suction
Hello, this is Ava with Think Crucial.
If you are experience less or no suction of you vacuum, most of the time there is a blockage that clogs up your unit resulting to this. Turn off your vacuum first and unplug the machine from the power before doing any troubleshooting with your vacuum. Remove the attachment hose and check inside the hose and the openings where the hose attaches for any blockages. You may refer to your manual below for troubleshooting solutions:
Electrolux EL8502 User Manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jun 18, 2014 | Bissell 9200 Upright Vacuum
Lack of suction at power unit
Check that the Handle has a slider to adjust air flow, Electrolux Vac's arent really designed for carpet cleaning, check hose for breaks or cuts and everything is secure, while its on run your hands all over the hose and vac to locate any air flow that should not be.
Let me know.
Nov 15, 2007 | Electrolux Centralux Vacuum
My rechargeable "Pronto" vacuum has lost most of
First I would ask you to check the filter. There are two filters, one inside the other. Pull the filter out of the hand unit, stick your fingers down inside the filter and hold the outer filter and pull them apart. Be sure to clean the inner filter as well to re-claim some lost suction power. Please check the hose from the floor unit to the hand unit make sure it is clear and fits well. There has been some problems with this models battery's and you may be able to claim some repair due to a recall. I can not find a dealer in your area. But you can check the Electrolux support site.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The low speed for bare floors won't work at all. The regular speed for vacuuming carpets turns on but spits items back out after a little bit.
An advice is more like it. What I do in a situation like that is to see if the air flows freely into the machine to see it here is an ubstruction or that the bag is full.. If that is OK II put the brush "down" and high speed on and sweepthe floor.
Then there is always the "troubleshooting" chapter in the manual. If the manual is lost in it´s printed form then look for Electrolux on the "net" there you will find your make, hopefully.
Jun 12, 2010 | Electrolux Central Vacuum
Seems to be a short in the power nozzle (light and beater bar sporadically work) while suction is just fine. How to fix the short?
I am having the same problem...great suction but unit on the floor won't vaccuum. I hit the reset button and the rollar still won't work!
Feb 21, 2010 | Electrolux Central Vacuum
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
Oct 24, 2009 | Electrolux Central Vacuum
Electrolux Epic 2500 suction stopped
It could be the switch or could be the suction motor. Also, there is a thermostat on the motor that will shut it off if you don't have the air flowing to keep it cool. If that is the case, the motor will re-start after it cools down.
If the motor dosen't start, the cheepest way to start is to buy a new switch and install yourself. Just make sure where the wires go. The single terminal is to the front and the two terminals to the rear. The black wire goes to the front single terminal, the red wire goes to the far back terminal and the blue wire goes to the front back terminal. The suction motor should come on first and then the power nozzel. If not in that sequence,reverse the blue and red wires.
If that fails, take it to the Aerus/Electrolux shop.
Sep 01, 2009 | Electrolux Vacuums
No suction but good exhaust flow
This sounds like you have a loose pipe connection somewhere in your system. Physically check all connections. If you can't find anything suspicious, call a vac repair man that specialies in central vac repair. Joe
Aug 10, 2009 | Electrolux Centralux Vacuum
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
Mar 07, 2008 | Electrolux Central Vacuum
Vacuums Logo
332 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
