Question about Bosch Classixx WFC 2465 Front Load Washer
Leaking my machine is leaking out of the clean out knob! what do i do? greg
  • 213 Answers
Remove the clean out knob from the drain pump make sure theres nothing stuck in the threads where it screws in. if theres nothing there replace o-ring on the clean out cap
Posted on Nov 20, 2007
How do I remove the shifter knob ?
How-to remove shifter knob from a 2008-2014 Dodge ...
? 3:14
Sep 24, 2014 - Uploaded by jghdez89
How-to remove shifter knob from a 2008-2014 Dodge Challenger ... 75 Cent Mod, 2012 Dodge Charger R/T ...
shifter knob change - YouTube
? 0:38
May 9, 2008 - Uploaded by promise383
s/v/c70 and s/v40 auto shifter change. ... How to replaceautomatic shifter with any knob and boot you want. - Duration: 6:12. Greg Green ...
2013 GC SE - Shifter Knob Remo
Jan 13, 2016 | 2013 Dodge Grand Caravan
We have a water leak coming from beneath our machine . Fault reports = 'OE'. what is the problem?
OE is really DE = Drain Error. This should have nothing to do with your water leak.
For the DE code, open the access panel on the lower left on front of the washer. Drain the last of the water out of the machine using the small hose found there, then unscrew the big knob next to the hose and remove. Clean out this filter. If nothing is in the filter, replace pump motor.
The most common source of a water leak is a small hole in the gray tub gasket at the door opening. Examine it very closely, looking for rubbed spots which may have developed a hole.
Feb 20, 2011 | LG Washing Machines
Washer is blinking the code fl.
Greg, best thing is to take the drain pump motor out. get to the impeller and check for any obstructions. Normally the filter is on the frame of the drain pump assembly.
Jun 16, 2010 | Kenmore 23822 Top Load Washer
Leaking pump filter on GE Profile
get new seal for that knob
Mar 03, 2010 | Washing Machines
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change.
For Saeco Parts and Cleaning supplies visit
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Incanto deluxe is leaking
sometimes the spout in the door is kinda clogged. Take this out ) need phillips head) and clean it . Make sure to turn the knob on it to left and right while cleaning.
There is no gasket but the little plastic pipe goes in there.
Should help.
Check this for parts SAECO
Jun 01, 2008 | Saeco Incanto Classic Espresso Machine
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Feb 25, 2008 | Washing Machines
Bosch Classixx WFC 2465 Front Load Washer Logo
32 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
