Question about Whirlpool Duet GHW9150P Front Load Washer
Inside of the washing machine one of the humps or bars broke off. now I have sharp pcs of metal where the hump was attached sticking out. I cannot attach it because the little metal hooks broke.
  • 240 Answers
Did it rust? if the metal of the basket broke off then there is not much to do for it. if it is just part of a clip that goes with the baffle then replace the baffle. I would take the baffle to a parts store to compare, they would be better able to help from this point. replacing the basket is something you would find out of the question by cost/labor. if you have a first source servall or appliance parts depot then they would be best. some service companies sell parts too but they would cost more and would have to endure a sales pitch for service
Posted on Jul 11, 2009
  • 3,037 Answers
If you call whirlpool or the place you bought it from then they can send you a new part and if it is under warranty then they will fix it for free too for you. Nothing to really worry about with this one. You could also get the current part fixed at a repair facility.
Benjamin
Does it make a difference if my spa replacement motor only has one hump not sure what it's for and the original I'm replacing has two humps?
Under the hump, is a capacitor. So that two hump is a motor that has two capacitors. I would suggest getting a like replacement.
5 BHP
4 HP
Same Difference... It's a game the pump manufacturers play to fool the consumer.
Fantastic info here:
Up Rated Versus Full Rated Pumps and Motors
Mar 17, 2015 | Waterway Garden
The door pops when you open it. it is centered around the roller assembly in the door that holds the door open when on a incline. the rollers move with the arm instead of spreading to go over the hump
try applying some WD-40 or light penetrating oil to see if it improves but it the rollers move then there is a chance that something has broken
Jan 21, 2014 | 2003 Buick Park Avenue
Front loader washing machine inside hard plastic bar broke off
there are several kinds of plastic cement..everything from superglue to plastic pipe cement like plumbers use..available at most hardware stores..even model glue..I would try one of these before pitching the washer..you nmay be able to screw it on using stainless steel sheet metal screws also..
Jan 15, 2014 | Kenmore Washing Machines
Need help putting back together
That plastic wheel has humps on it. The small copper winding is a motor that turns that wheel. As them humps on the wheel travel around slowly they open or close those points which power up the water valves motor and such. This type timer is not serviceable and cannot be repaired. You must purchase another.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 12, 2013 | Washing Machines
Clunking going over bumps on 1.4 fiat grande
Alright whos been speeding whilst going over the speed humps ,what you have is a classic case of speed hump syndrome ,by going too fast over them you have damaged the antiroll bar connection stays or connecting rods ,look on the suspension and from the antiroll bar to the suspension leg is a short link bar with a ball joint on each end and these i am sure you will find are damaged as this is a common syndrome i am getting over the last couple of years with the increased use of the sleeping policeman to reduce the speed of traffic
Mar 28, 2013 | 2008 Fiat Grande Punto
My front fork sounds when it goes onto the hump
Check for a dent in the housing that is binding up the movement of the fork
Feb 11, 2013 | Cars & Trucks
How to replace the spark plugs on 2006 E 150
MOST VANS HAVE A HUMP INBETWEEN THE SEATS UNDER THE DASH! THERE SHOULD BE A LATCH ON EACH SIDE OF THIS HUMP, THAT WILL LET YOU GAIN ACCESS TO THE ENGINE FROM INSIDE THE VAN! FROM THERE YOU CAN REPLACE THE PLUGS!
Mar 05, 2011 | 2006 Ford Econoline Cutaway
Where can i locate the heater core in the type S
If you are looking at the engine from the front of the vehicle. on the Right hand side, there should be a metal hump coming out of the firewall. It is on the other side of that hump, and should be acessed from inside the vehicle, behind the dash on passenger side.
Jan 04, 2010 | 1996 Honda Prelude
2000 PONTIAC FIREBIRD FUEL PUMP REPLACEMENT
Many of the Pontiacs of that era up to even present models had an access panel in the trunk that you could access through the back seat pass through.
Its been a while since I seen the inside of a Firebird, but in thinking about it the back seat pass through may not be present on the Firebird, but it may be worth the time to lift up the carpeting in the trunk area and see if there is an access panel to the fuel pump.
Dec 30, 2008 | 2000 Pontiac Firebird
Whirlpool Duet GHW9150P Front Load Washer Logo
111 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
