Motorcycles Logo
Posted on Jun 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE A1456W LED camera keeps discharging my batteries even if it's off.
adam bikedoc
Level 3:
  • Motorcycles Master 695 Answers
  • Posted on Jun 14, 2015
adam bikedoc
Motorcycles Master
Level 3:
Answers
695
Questions
Helped
153831
Points
2058
You would be better of posting the question in the camera section,this is the motorcycle one.
How to Install Arlo Pro 3 Floodlight Camera?
There are some very easy and quick steps that will help you to do a proper Arlo Setup . You first need to install the Arlo Pro 3 Floodlight Camera properly.
Kindly follow the further steps to Setup Arlo Camera:
Open the battery compartment by squeezing the hook and pulling back tenderly.
Embed the battery as displayed and close the battery entryway.
Carry the camera inside one to three feet (30 to 100 centimeters) of the base station.
Sync the camera to the base station:
In the event that you are utilizing an Arlo base station, press the Sync button on the base station for around two seconds and afterward discharge the button.
Note: If you press the Sync button on the Arlo base station for a really long time, the LED under the USB image flickers golden for 10 minutes. While the USB LED is flickering golden, the sync interaction is obstructed.
Assuming you are utilizing an Arlo Pro 3 base station, press the button on the highest point of the base station for around two seconds and afterward discharge the button.
Sit tight for the sync status LED to squint green.
Press the Sync button on top of the camera for around two seconds and afterward discharge the button.
A blue LED on the camera flickers quickly to affirm sync.
In the event that the LED on the camera squints golden, the sync isn't effective. You should rehash the sync interaction.
Check the camera LED on the base station.
In the event that the camera LED on the base station turns strong green, the sync interaction is finished.
Rehash these means for every camera.
Note: If you don't finish the sync cycle within 60 seconds, press the button on the highest point of the base station and attempt once more.
Enter a proper key phrase to not face Arlo Login Issue .
Hopefully, you will be familiar with how to install Arlo Pro 3 Floodlight Camera. Proper installation helps to solve Arlo Camera Offline issues also.
1helpful
How do i reduce the picture size using a ge a1456w
Follow the instructions on pages 20-22 of this manual.
Jan 22, 2013 • Cameras
1helpful
Reducing picture size ge A1456w
My camera is not turning on sometimes for a minute or so and than it works just fine so i returened it an d im having the same broblem with the new one why
Sounds like weak batteries.
Replace them or recharge them.
Keep in mind that batteries will discharge even if the camera isn't being used.
Crat
Oct 25, 2009 • Cameras
2helpful
The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised inside...new battery required i'm affraid!
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
1helpful
2answers
Panasonic DMC-FX07 Digital Camera won't turn on.
Check your batteries, but otherwise it could be a power board. It could cost between $90 - $125 to replace the board
Ixus 75 battery discharges overnight even if the camera is turned off.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
2answers
Batteries discharge rapidly and even spontaneously
I have the same problem. I believe the camera is defective since the rapid discharge has ocurred since I bought the camera in June of this year. My sister has the same camera which she bought at least 2 years ago. Her batteries last at least triple the amount of time as mine do and she takes far more pictures that I do. As an experiment, I used her batteries in my camera and they discharged after 30 shots at the most. When the same batteries were recharged and loaded into her camera, the batteries lasted for more than 120 shots. I'm really frustrated. I bought this camera per my sister's recommendation and it cost more than $350. The store has offered to send it back to Sony for a fee but I'm afraid Sony will say I am at fault and not replace or refund.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
