Question about Microsoft Windows XP Home Edition
Desktop icons the icons on my desktop, are highlighted when they appear and the icons disappear completely once I log off the internet.
  • 124 Answers
Re: desktop icons
In Windows XP, using more than one user account allows each user to customise their desktop icons. Try browsing to C:\Documents and Settings to see if different user accounts really have been created.
Posted on Mar 09, 2015
    Uploaded 5 video answers.
  • 150 Answers
Re: desktop icons
Your problem is so simple just listen see below
1.go to desktop
2. right click there arrange icon by
4.then in second last their is lock desktop icon
5. click their your prob is solved
if go to desktop right click their and click properties
then click desktop
then click customise desktop in web their is lock desktop icon put tick out from their your prob is solved enjoy
Posted on Nov 15, 2007
0 characters
3 Points
Desktop icons have disappeared
right click on the task bar a the bottom of the screen the 5th option will be show the desktop click on it! if this is helpful remeber me to vote!
Sep 21, 2011 | Microsoft Operating Systems
Runtime error 216 at 00Cd358
Run time error 216 can cause permanent damage to your operating system if left unrepairable.
Symptoms of Run-time Error 216 This Trojan invades the registry and modifies command files, sometimes with unpredictable results. Some of the common symptoms include:
  • Inability to open some programs such as internet explorer
  • Random CD/DVD drives opening and closing
  • Pop up dialogue boxes appearing randomly
  • Appearance and disappearance of important files
  • Extremely slow downloads
  1. Boot to safe mode by pressing the F8 key at start up
  2. Once the system has booted run a good anti virus program to eliminate the Trojan
You will need to also use a good registry cleaner to fix all of the entries that the Trojan modified. Once all that is done, the error should disappear for good.
summary Any time you have a virus, Trojan or other form of malware that causes a noticeable error in system behavior or performance, you should run a manual anti-virus and spy ware scan. Once that is complete, you should run a good registry cleaner to remove all of the damage and left over junk entries these programs can leave behind after they are dead.
Aug 17, 2011 | Operating Systems
Icon changing to generic windows
Steps for Changing a System Icon:
Right-Click your desktop and choose "Properties". Then follow the steps below.
1. Click on the "desktop" tab at the top of the Display Properties window.
2. Then click the "Customize Desktop" button.
3. A Desktop Items window will open. Choose the "General" tab.
4. From the dsplay of system icons, click on the icon you want to change making sure it's highlighted.
5. Click on the "Change Icons" button. This will allow you to browse your computer for the icon you want to use as a replacement for your System Icon. (remember to click "OK" and "Apply Changes" once you have chosen a new icon).
Jan 30, 2010 | Microsoft Windows Vista Ultimate Edition
Windows Vista shortcuts disappear!!
Basically a friend showed the power 4 extreme option by right clicking on the battery icon at the bottem right of the screen and then setting in the quiet office section to say no to hide desktop icons. Now its no longer a problem!
Sep 01, 2009 | Microsoft Windows Vista Home Premium with...
Desktop icons disappeared after installling
right click on desktop in a free area --> arrange icons by -->show desktop icons
If thats not got a tick mark next to it then click on it and press F5 to refresh the screen
Jun 04, 2009 | Microsoft Windows XP Home Edition
Recyclebin rename
Hi there,,
Please follow the instructions:
  1. Click Start / Run
  2. Type regedit and press enter.
  3. Open the HKEY_CLASSES_ROOT folder
  4. Open the CLSID folder
  5. Open the {645FF040-5081-101B-9F08-00AA002F954E} folder
  6. Open the ShellFolder folder
  7. Change the "Attributes" data value from "40 01 00 20" to "50 01 00 20". Once completed change the "CallForAttributes" dword value to "0x00000000" (double-click and change value data to 0). You must change both of these values to get the rename to appear.
After performing the above steps you will be able to rename the icon like any other icon. Right-click the Recycle Bin icon on the desktop and click Rename and rename it to whatever you wish.
Vipin Menon
Mar 16, 2009 | Microsoft Windows XP Professional With...
I use Microsoft Windows XP Professional SP2
Download this utility and save it to your desktop. Disable any antivirus or anti-malware applications
you have running. Double click the icon once the download is completed. Do not interfere with the
program once it begins. You can sit back and let this utility do its job including the installation of
Windows Recovery Console.
Make sure also that your machine meets system requirements for the games you intend to play.
Update your display drivers and acquire the latest directx drivers.
When complete restart your computer and click START.....RUN.....then type msconfig
and click OK. Click BOOT.INI and under "operating systems" view the order they
appear in and if the one you want to load on boot is listed second......highlight the
first one and click "move down". Next reboot the machine to view the change you've
made. You want the Recovery Console /cmdcons to be placed as your second
boot option. Conceptual View
Good Luck.........Nate P.
Jan 16, 2009 | Microsoft Windows Vista Home Premium with...
My desktop does not appear need help.
scan your pc for viruse in safe mode by disabling the system restore
Apr 29, 2008 | Microsoft Windows XP Home Edition
XP Pro Problm
can you explain the problem more? what do you mean vanished? does the screen fade out to white or black, or there is a blue screen with white text, or does it restart the whole system?
Mar 05, 2008 | Microsoft Windows XP Professional With...
No icons on the desktop
hi if you right click your mouse on the center of the desktop a menu will come up highlight the one that says arrange icons by another menu will appear make sure that show desktop icons is checked to the left if is isnt check it by clicking on it and the icons will appear. hope this helps.
Jan 05, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Home Edition Logo
176 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
