Question about Bushnell NorthStar 78-8831 (525 x 76mm) Telescope
Motors dont work even with new batteries
I cannot grt the motors to work on my 78-8831. I even tried new batteries. Is there a fuse?
I had the same problem. I removed the motor and drive assembly and used a pair of pilers to gently rotate the drive gear a few times in both directions. I re-installed it and it began to work again. I also noticed that the grease on the drive gear and shaft was very thick. Cleaned and up and re-applied a lithium based grease and it helped even more. Be sure to remove all old grease from the aluminium block that the drive gear shaft rest in. Good luck.
Posted on Feb 19, 2012
I posted to a problem with the handset not working and I'll ask the same here. You are switching on the small black button by the battery compartment? It should light up red and power up the handset. Then it's just a case of going through the menu, picking an alignment point and the telescope should start moving automatically.
Posted on Jan 19, 2008
Y did all my sound stop working in my 2008 buick truck???and how could i get it back working??i have NO sound..not even the seatbelt or the truning signals sound off
try all fuses for items you have described. Some fuses can grt brow on fuse leg post if so either clean or put new fuses in. its cheapest option to try first.
Mar 15, 2016 | Buick Cars & Trucks
Could my rear window wiper motor drain my battery. new battery installed one month ago and something is drianing the battery completely. I noticed my rear wiper isn't working.
i have a 99 chevy blazer..the rear wiper motor is blown..i dont want to pay for a new one, since i barely use it..so i just opened up the fuse box and removed the fuse..easy fix..let me know if this works :)
Nov 29, 2010 | 2004 Ford Expedition
2007 PT Cruiser basic RAD fan battery relay feed replacement
grt one at any parts store, it should be in the fuse or electrical box, look in the owners manual, pull out the the ole and plug in the new
May 08, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
Driver side window isnt working but the rest
I believe you need a new switch in drivers door goto a wrecker , new GM ones are $$$$$, happened to me, i just unhooked battery to clear a CEL and had window open at the time ( won't do that again ) and door locks and drivers window won't work ,, checked fuses ,everything good then took door apart and put power to window motor was able to put it up, googled and found lots of people in same boat , hope it works for you ,,,,D
Nov 27, 2009 | 2005 Chevrolet Colorado
Blower not working
it could even be the blower motor, since u replaced the heater resistor pack, check to see if the blower motor is working, then check the fuse
Feb 17, 2009 | 1999 Honda Civic
My 1983 Honda Civic wont start
check fuses under the hood the main fuse may be blown are the crank fuse
Jan 24, 2009 | 1983 Honda Civic
98 Ford Contour not charging
I dont know if yours is a 4 or 6 cyl. On the back of the motor by the firewall there is a 175 amp mega fuse inline on the positive cable comming from the battery. On the 4 cyl it is below the air box center of the back of the motor. On the 6 cyl, it is below the coil pack on the center back of the motor. Be sure to disconnect the negitave battery cable before you attempt this. There is a 3 inch long cover you pop off and you will see it. It takes a 10mm socket to unbolt it. Remove the fuse and ohm it out, if there is no continuity, you have a bad fuse, replace it. I have had 3 people replace their bats and alts ($350 in parts) just to find out it still had the problem. An $8 fuse. Good luck and hope this helps..
Jun 30, 2008 | 1998 Ford Contour
91 dodge dynasty blower motor
trace the two wires by analyzing which power are you missing...
run a wire from the positive of the battery and put the red wire of the volt meter to it and place the black wire of the meter to the black that goes to the motor.
if there is 12 volts, you have a negative terminal to the motor.
if you dont have, then you dont have the negative terminal to the motor.
next transfer the wire from the positive terminal of the battery to the negative terminal of the battery.
now put the bllack wire of the meter to the wire and test the red /or blue wire that goes to the motor.
it should have a reading of 12 volts.
if there is no reading , then there is no positive 12 volt present on the blue/red wire.
from these test, you can know which wire does not have the power.
that is what you are missing..
tnx 4 using fixya,
cheers,
drcool
p.s.
you could have just missed the black wire to be screwed on the housing of the blower motor.
Jun 29, 2008 | 1991 Dodge Dynasty
Keeps saying to change batteries
It occurred lately with reloadable NiMh-batteries.
When I put in some alkaline batteries I had no problem.
I cleaned the contact surfaces of the NiMh-batteries and the contact surfaces in the camera. Up till now I have had no problems.
grt.
Aad
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
Bushnell NorthStar 78-8831 (525 x 76mm) Telescope Logo
177 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
