Question about Remote Controls
Code needed I need a code for a 6 in 1 universal remote RCT2415AR for a centrex 68cm TV
Re: code needed
This is yet one more piece of cheap chinese junk, throw it away and spend a few extra dollars on a learning one, Do your homework first.
Posted on Apr 16, 2008
0 characters
3 Points
Centrex remote control code
028,011,043. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 16, 2013 | Universal Remote Control Remote Controls
I need Dynex tv codes for universal remote programming
Jensen remote has no setup code with Dynex tV. Avex-6 universal remote has setup code for Dynex TV. The code is 399
Mar 22, 2012 | Jensen JR300 Remote Control
Hi need code for ancient centrex tv for universal remote help aaaaaaaaaah
Centrex is not listed with URC04110 universal remote coldes. But you can search and find the code for your device with this remote control. I'm not sure will it work with your old Centrex TV. Anyway try. Wish you the best.
If your device does not respond to the remote control after trying all
codes listed for your brand, or if your brand is not listed at all, try
searching for your code. For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
NOTE: In the search mode, the remote control will send IR codes
from its library to the selected device, starting with the most popular
code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1 through
5, but substitute the appropriate device key for the device you are
searching for.
If you have set up the remote control using the Searching For Your Code
procedure, youmay need to find out which four-digit code is operating
your equipment:
For example, to find out which code is operating your TV:
3. Enter 9 - 9 - 0.The LED will blink twice.
4. To view the code for the first digit, press 1 once.Wait 3 seconds,
count the LED blinks (e.g., 3 blinks = 3) and write down the number.
NOTE: If a code digit is "0", the LED will not blink.
5. Repeat step 4 threemore times for remaining digits.Use 2 for the
second digit, 3 for the third digit, and 4 for the fourth digit.
6. To check for codes of other devices, repeat steps 1 through 5, but
substitute the appropriate device key for each device you are checking.
Mar 08, 2011 | One For All URC4110 Remote Control
Device code for universal remotec remote
I need the model number of the remote to help you.
Apr 15, 2009 | Universal Remote Control 6-Device...
5 digit Remote Code for Centrex TV
You should only need a 4 digit code. Try 0056 for a Centrex TV.
Nov 04, 2008 | One For All URC4110 Remote Control
Universal remote codes for cobolt tv
0698 - It's about than 40 codes in if you are searching manually.
Aug 29, 2008 | Universal Remote Control Remote Control
Need code for universal remote control
I'm seeing codes 0808 and 0854 could work...
The original codes from the EU URC7711 manual are
Centrex 0780 0891
Also try these
0037 0178 1437 0556
If no luck... go buy a 7$ GE universal remote they work for even the most stubborn TV's
Also when you do the manual search function you have to press enter 999 times before you start the list over... so if you got frustrated... like after 100 tries... you only made it to code 0100 the list ends at 0999
May 05, 2008 | Remote Controls
Unable to tune in generic remote control
I have the code book for this remote.  I am having difficultly with my Sharp CD player.
Codes for panasonic tv 0011,0024,0032,0106,0118,0131,0139,0212,1083,1140
codes for pioneer dvd
hoped this helped someone
Dec 29, 2007 | Universal Remote Control Remote Control
Remote Controls Logo
157 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
