Question about Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Samsung 50" DLP TV - I replaced the bulb on the tv and the lamp light is still on HL P5063w - lamp light is blinking on front of TV....The TV is not working...I do hear activity in the back...just no light on screen...even after bulb replacement.
  • ekk202 Aug 25, 2010
    I have the same problem. high pitch whine is there and lamp is on. power up audio but lamp light blinks. not picture. may be associated with power surge. any resolution yet?
I had projection bulb go out (explode) in my toshiba DLP tv. Pulled out bulb and housing assm. and could see it. Ordered a replacement bulb online, an aftermarket one and replaced it. Lamp led would keep flashing, blue led on, sound ok but still no picture. You could hear tv going through its self reset and after eight attempts red lcd came on. Info online suggested lamp door not seated properly, rechecked and door fine. I pulled bulb housing and made sure it was completely seated and it was in as far as it goes. Checked bulb housing contacts and they looked ok. The aftermarket housing assm. did not "feel" the same as the original when installing into tv even though they looked identical. Swapped new bulb into old housing, cut old harness and plug off of bad bulb and crimped on new ends at bulb end reusing original plug and harness (observe new bulb harness to keep wire locations correct) reassemble and install housing. Worked as soon as tv turned on. Watch out for non oem parts, they may look identical but something may still not be quite right.
Posted on May 17, 2012
    Problem Solver:
  • 17 Answers
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
I have a Samsung HLT5076S DLP Tv and when I turn it on I get a blinking Green Light for a couple of Mins. Then after awhile all three light start to blink. The standby light is Red and the timer and the...
It is the lamp but try to check the filament of the lamp if defective because if the color wheel is defective you will hear a whirring noise. Try to check the lamp if defective replace it and if you replace the lamp you should reset the lamp hour meter, feel free to send feed back good day and best regards.
Aug 22, 2011 | Samsung HL-T5076S 50 in. TV
I can hear the movie but do not get a picture but the lamp light is blinking
Ur tv Projection lamp is dead.Ur tv Projection lamp,require replacing.The "LAMP"LED light indication blinking flashes or stay on.The projection lamp must be replaced,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a new projection lamp.
Aug 04, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
My tv is no working stand by light and bulb
Without doing alot of research I see that you have a dlp TV. If the light for the lamp is blinking and your unit is 6 years old or older you should replace the lamp. It is definitely bad. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will walk you through it. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 25, 2010 | Samsung HL-S5086W 50" HDTV
I have a samsung 50 inch dlp. not sure what model number. it turns on and off automatically while pluged in. the display lighs blink simutamiously. please help
One of the display blinking lights?It said bulb or lamp?If yes,ur projection bulb need it replaced,it life exspan,it over.It require a new projection bulb.
Apr 28, 2010 | Samsung DLP HL-P5663W 56" TV
I just replaced the DLP Lamp and housing on a 50' Samsung DLP tv.
CK your Fans make sure they are running or set will not come on.also if you can solder resolder power supply board.
Apr 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
2,202 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
