Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Frig leaking water
Ice tray leaking water with the main valve shut off?
This may be a bad pump.You can remove the back of your unit (make sure its unplugged when doing this). With the back removed leave the water supply on. Observe where the water is coming from. If it from the pump area, or if you see some white corrosion on it, it is likely the pump. This is a VERY easy fix. Obtain a new pump for your specific model. Shutoff the water supply in the wall that feeds your unit. Unplug the unit. Remove the power plug from the pump. Observe and take notes on what tube goes to what opening.Unscrew the tube nuts from the pump, making sure you have a towel nearby as you will get some water from the tubes.for easy reinstall have a good look at how the pump sits in the unit before removing it.) Remove the mounting screws holding the pump in place and remove the old pump ( Using the old mounting screw(s) remount the new pump the same way the old one was situated. Before reinstalling the tubes make sure they are free of wear. In some units you can slide the tube nut back and cut the tubbing to get a fresh connection (if you do this be careful not to cut too much off because there is usually very little slack). Re-install the tub connections and screw the tube nuts back in. reconnect the wiring.. Clear all of your tools and towel away from the unit opening and make sure the floor is complely dry. Open the water supply from the wall, and make sure there are no obvious drips. Now, plug the unit back in, check the pump again, care not to touch anything inside the unit while its plugged in. If there are no drips have someone fill a cup of water from the dispenser in front while you observe the pump. If you have no drips then you are all finished!
Posted on Jan 14, 2008
  • 291 Answers
Sounds like the water valve is not sealing all the way... you can take the hose off the water valve in back of the refregerator and put a cap on it frig leaking water - 53560ac.jpg
Posted on Nov 15, 2007
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
Water is leaking when ice maker gets water from main line, it leaks from the small plastic hose where the line goes into the top / back portion of the frig
In most cases that is caused by a slow water leak in that side of the dual water control valve. When your ice maker calls for water it turns the water on for about 7.5 seconds and water is sent to fill the ice tray. But if water should slowly ooze by the valve while off the water tends to freeze in the end of the fill tube causing the ice to make the water go everywhere but the correct place. Sometimes the fill tube can be cracked by this problem. Using a hair dryer will help for the temporary time. Best thing to do is turn the water supply off at its source and remove the water control valve and clean out any debris that may be causing the valve to stick open and a pre-filter before the valve is needed in severe cases. Sometimes the valve has the seat damaged and will need replaced. Yours is part number=> 4389177 If you have questions or require more help please let me know, Thanks, Sea Breeze
Feb 17, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My model GSH25KGRWW ice maker appears to be leaking where the water enters the ice making mould or around that area. There is a buildup of considerable amount of ice. Is there a seal in that area that can...
Could be that the water shut off valve is stay open too long and excess water is not in tray and freezing over. There is an adjustment on the icemaker for the length of time it loads water. Lessen it.
Sep 03, 2017 | GE GSH25KGRWW Side by Side Refrigerator
No ice....slow to refill ice tray
You need to check the water pressure coming from the water shut off to the frig. Sometimes right at the shut off debris gets in and the water comes out really slow.
if this isnt the problem then it could be one of three
water valve not opening 100% (replace)
ice maker timer is not working properly (replace)
the tube that feeds the ice maker is frozen
Mar 28, 2010 | Refrigerators
Water running under frig.
have you tried turning the water off(if you have a tap/faucet behind unit).....
Feb 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker no longer making ice. A few weeks ago the water that was supposed to fill just the ice tray, didn't turn off, overflowed the ice tray and proceeded to fill the ice basket underneath. Since then...
Sounds like the water flowed enough to freeze the end of the fill tube shut. Best to prepare to replace the dual water control valve on the rear and near floor of refrigerator. If it was leaking and you should thaw the tube you need to turn the main supply of water off until replaced. Then thaw tube and replace the dual control valve. I will return with a part number providing your model number is correct, Thanks, Sea Breeze
Jan 17, 2010 | Maytag MBB1954G Bottom Freezer...
Ice maker is making ice but leaking alot of water under the fridge and in the freezer. What can I do to shut if off until I repair the ice maker?
pull our your frig. and follow the water line coming into it. the other end should have a valve on it in the floor or the wall. turn off the valve and that will stop any water from coming to your frig for water or ice making.
Apr 22, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
91 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
