Hi Barbara:
The pull start assembly is usually attached by 3 or 4 bolts.
Start by removing it. Depending on where the pull cord broke, you may be able to use it shortened a bit, but replacement is probably a good idea.
There is a spring inside the thing the cord winds around (spool)that retracts it after you've pulled on it. The tricky part is making sure that the spring is wound up enough after you've installed the replacement cord.
Look at the way the old cord is installed. If you can, grab it with some pointy pliers and pull it all the way out, winding up the spring tension at the same time. There should be a way to hold the spool (look for a hole you can slip the end of a nail into) so you can change the cord. Then Take the nail out and make sure the cord retracts all the way.
Next step is to re-install it on the mower.
Cheerfuls!
