Question about Samsung LN-T4665F 46 in. LCD Television
My Samsung TV (LNT4665FX/XAA) is not coming on. When you hit the power button the tv starts clicking like it is trying to come on but you never get a picture.
    President:
  • 563 Answers
G'Day!
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
I just contacted 800-SAMSUNG on the same problem. The operator was very courteous. She identified my TV as out of warranty, she checked on a list of "suspect" models and serial numbers, and then she asked me a few troubleshooting questions and again confirmed the symptoms. <br /><br />After that brief exchange, she set up a repair ticket. I had to agree that if the issue is "other than the capacitor issue" the repair is on me, otherwise it's on Samsung. I agreed to that condition (my TV, the LNT4665FX/XXA, MFG JAN 08, shows in virtually all on-line forums for this issue). I just need to get into their repair cue, which is a few days in my location. <br /><br />All in all, except for having the issue in the first place, you can't ask for more. Way to go SAMSUNG! <br /><br />(Thank goodness for forums and the internet. I'm sure the first customers who saw this problem had big hurdles to overcome).
Posted on Aug 20, 2010
    New Friend:
I fixed mine read this! My tv was a lnt-4556-fx/xaa which had problems turning on and off. it would eventually come on but this was after unplugging and plugging back in. after calling samsung they came out and replaced the capacitors and then whe whole power supply board. the issue remained. After looking for solutions i established it was the main board to be the problem because the red light in the lower corner of the tv was doing abnormal things. and the tv would not shut off properly. If the main board had not been an issue i would have replaced the tv's Tcon board. I fixed my tv with a new mother board! The board that is normally in this tv is a BN94-01199Q Main Board I instead bought a BN94-01518P because it was a board that also works for the tv according to shopjimmy.com where I bought it. Hope this helps anyone.
Posted on Aug 16, 2013
Samsung txr3079whx/xaa 5 blinking lights
5 blinks to Samsung indicates a fault in the main power supply output voltage.
Jan 23, 2013 | Samsung Televison & Video
LNT4665FX/XAA has a cracked internal screen
go to a repair shop and see if it can be replaced and the cost? or buy a new tv if it is not worth it.
May 23, 2011 | Samsung LN-T4665F 46 in. LCD Television
I have a samsung flat screen model # LNT4665FX/XAA that is about three years old, when I turn it on it clicks about 6 times before coming on. What could be the issue? It also seems to flash pixels...
Your TV most likely has faulty capacitors in the power supply section of the TV. This is a failry common problem.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
2c07611.png The number one cause for the symptoms above are faulty capacitors within your Plasma or LCD TV. The number one reason that these parts fail is that TV manufacturers often times use lower grade capacitors in their efforts to reduce costs. After several years these lower grade parts will tend to fail first. To insure that these parts will not fail again its imperative that they are replaced with high temp, high quality, low-ESR caps. You can find the parts online from sources like Digikey or you can get complete reair kits incuding the parts, repair instructions, and support from www.TvRepairKits.com
Dec 15, 2010 | Samsung LN-T4671F 46 in. LCD Television
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LNT4665FX LCD-Clicks before coming on
Bad power relay get it fixed before you have more issues the psu cost around $25 bucks on ebay good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 15, 2009 | Samsung LN-T3253H 32 in. LCD Television
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung LN-T4665F 46 in. LCD Television Logo
2,039 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
