Question about Sony Playstation 3 (PS3) Console
There is a sd card stuck where the cd should go. There is also a disk there. Do you know how to fix it?
There is a sd card stuck where the cd should be. There is also a disk there. How can it be fixed ?
My boss' son left a Playstation 3 on my desk to ask me to take some disks from the slot where his 2 years old daughter (my boss' granddaughter) might insert some disks into it. Knowing opening it may void the warranty, so I figured out an alternative, I hope it will work for a SD card.
1. Get a wide rubber band (the wider the better), the thickness should be 1 mm -2 mm thick. I used a 5mm wide rubber band loop and cut it to form a rubber strip.
2. Use a toothpick to gently push an end of the rubber strip into the disk slot. About 1"-2" of the rubber strip should be pushed into the slot.
3. Remove the toothpick, with one end of the rubber strip in the slot, then pull out the rubber strip quickly, the stuck disk may come out with the rubber strip. In my case I got two disks out from the slot.
Note: There might be risk of damaging the laser head in the slot, I have no idea where the laser head docked. If you are not sure, contact Sony to seek a solution. I am not responsible for any damage when using my method.
You can also overlap the rubber strip to form a horizontal U shape, and use a toothpick to push the bottom inside the U shape strip into the slot, and pull the bottom end of the U shape strip out suddenly, the disk will come with it.
Remember to clean the rubber band before you do it, free from powder, and should be dry.
Zhu Ni Hao Yun, that's to say Good Luck in Chinese.
Posted on Feb 25, 2008
    Problem Solver:
  • 6 Answers
Ye dont put sd cards where the cd should go lol
Posted on Nov 16, 2007
  • 709 Answers
If you can see the SD card, Get a toothpick and wrap Tape onto it then reverse the tape so that you have sticky on outside. See it you gcan retract it that way. You risk damaging the Disc eject system if you try to force the disc to eject by pressing the eject button more than 10 seconds. Once you get the SD card out you can do the 10 second eject button thing.
Posted on Nov 15, 2007
SD Card and disc stuck in CD slot of Alienware M14x?
try taking a small piece of wire and bending a small hook into one end slide it in on TOP of the stuck disc and hooking the center hole of the disc, (you don't want to get the wire under the disc because you could damage the disc reading hardware) also once you have the disk hooked you may have to use the tweezers to gently hold the front of the disc up to align with the slot as your pulling it out. you should feel a little resistance but don't try to force the disc out too hard.
Mar 23, 2015 | Dell Alienware M14x Notebook
Lost CD Driver
This is for you, if you lost your CD driver that came with your camera, and you don't know how to download your pictures to your computer. You don't need the disk to transfer your pictures from your camera to your computer. Follow these steps:
1. Take your sd card out of your camera.
2. Plug your sd card into your computer.
3. A folder with your pictures should appear on your computer.
4. Copy your pictures to a different folder on your computer.
5. Take your sd card out of your computer.
6. Your pictures will be on your computer for you to enjoy.
If that doesn't work, plug the cable in that came with your camera.
I hope this helps.
on Jan 07, 2009 | Polaroid i733LP Digital Camera
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
Sd problems
try a different sd, maybe the sd has bad sectors etc...You may need to run a check disk on it for...
Aug 05, 2009 | iLO CA3000V CD Player
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
Please feel free to let me know if this was helpful!
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
Hi j dll, If you send me a copy of the disc I will copy it onto a 1gb sd card and send it back to you. I have an extra 1gb card.
Contact me via email
Mar 23, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Canon digital camera solution disk
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
After downloading is finished, unplug the USB cable and run the software that you downloaded.
The software installer will tell you when to connect USB.
Nov 19, 2008 | Canon PowerShot SD1000 Digital Camera
I got a SanDisk 3 in 1 SD card. I don't know how to get music off of my computer to the tiny SD card to my phone.
You can connect the SD card to the Card reader or insert the SD card to the SanDisk 3 and then connect the SanDisk 3 to the pc. ( U need the cd utilities and install software to the ROM )
I f your SD card is connected to the PC you can directly copy the music from the PC to the SD card. SD Drive is created by windows found in " My computer" same is through with the SanDisk 3 connected to the PC. you can directly copy the music files onto the sand disk.
Do not rate me if this not solve the sytem. notify if you need more solution. melnavz
Apr 08, 2008 | Computers & Internet
CD & SD Card stuck in Asus Pro31F notebook
gant really help on the sd usually push in to insert and push in again to remove.
cant imagine how you can get cd stuck between rom and chassis.anyway if you look closely at your rom you will see a small push a thin piece of wire into this to eject the rom hopefully giving you more room to play with and remove disk.a paperclip made straight is an ideal tool for this.
as for repair;tell me your model and i'll check to see if I have it
I have nearly all hp service repair manuals,some toshiba and ibm
Mar 03, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
215 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
