Question about Gateway Tabor 3 (4000532) Motherboard
Updte to 1gig 100fsb 256 cache on 4000532 mobo. gateway intel 440what ever
I am stubborn and not to bright. I have read that you can make this proccessor work on this mobo. I updated the bios to 750what ever and it will not boot when I install the new 1 gig chip. tried slot one and secc adapt with cpu and fan. the comp lite just flashes and no boot. when I put old proccesor in it works fine.
  • 657 Answers
Re: updte to 1gig 100fsb 256 cache on 4000532 mobo....
I have heard that when you do this sometimes you need to hold reset for about 5 sec when powering up, you should then be able to change the CPU settings in the BIOS, however you do need to have the right BIOS version to do this.
also try resetting the BIOS (removing the Bios battery while unplugged), this should also give you an opportunity to set the processor speed in the BIOS.
Posted on Nov 15, 2007
0 characters
3 Points
Game problem
please install windows7 64bit and slove the probme
Apr 22, 2012 | Motherboards
I want to upgrade my PC's RAM from 128 to 512 MB Is is possible to add only single RAM or two 256 MB RAM?
Depending on your mobo, you can do either, add one stick of 512MB or two sticks of 256MB. If you're sure you get matching sticks if your mobo is DDR capable.
Jan 03, 2010 | Intel Motherboard
Need schematic for E-machine T2542
This is the user manual
here are Specifications:
CPU: Intel Celeron 2.5 GHz 128KB L2 cache &400 MHz FSB
Chipset: Intel 845GV
Memory: 256 MB DDR (PC 2100)
HardDrive: 40 GB
Jan 02, 2010 | E-Machines Motherboards
Is my mobo compatible with a 256 mb 128 bit fx5500 agp video card?
youre motherboad support intel pentium d 800mhz fsb processor and ddr 400, it has built in graphics, yes it will support a 256 128 bit fx5500 agp card, the agp 8x/agp 3.0 enhance graphics performance it support a high bandwidth speeds up to 2.12gb/s its twice faster than agp 4x,
Nov 22, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
What is the Maximum RAM that can be attached to Intel Pentium III with Motherboard "Gateway Tabor3 CopperMine WS440BX"...?
I had a look on the web and came across an answer. According to he site the WS440BX can only handle 384MB.
Hope this helps!
Please rate this..
Sep 27, 2009 | Gateway Tabor 3 (4000532) Motherboard
Will not boot past Logo screen with new XFX nvidia Gforce 9500Gt 1gig card
CHENNAI - 600 015.
PHONE NO : 98405-11595
Apr 30, 2009 | Intel D915GUX Motherboard
RAM Installation.
your new ram fsb speed not support your mobo
845glly mobo support 266 fsb 133 mhz sdram
Feb 29, 2008 | Intel D845GLLY Motherboard
Gateway Tabor 3 (4000532) Motherboard Logo
91 people viewed this question
Top Gateway Motherboards Experts
Brian Sullivan
Brian Sullivan
Are you a Gateway Motherboard Expert? Answer questions, earn points and help others
