Question about Dryers
Dryer starts but flame extinguishes after a few seconds
Model SDG515DAWW The dryer and flame start off working but flame extinguishes after a few seconds. when I try to restart the dryer the igniter glows but there is no ignition. The gas supply from the house is fine. Does the valve go bad on this model ? or is it a sensor ? I'm trying not to replace the whole system by poke and hope Thanks
  • 864 Answers
The flame sensor should be OK since the flame starts. (It senses that the glow plug is on to start the gas.) The problem is probably the secondary coil on the gas valve assembly. There is a kit available to replace the coils and it is not difficult or expensive.
Posted on Jul 11, 2009
  • 132 Answers
It is clear from your reading symptoms that is asensor thermostat problem
thanks
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
I have a gas Maytag dryer model #SDG515DAWW it makes noise but wont go on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Dryers
I have a 6 year old maytag gas dryer , model SDG515DAWW. it isnt heating and drying the clothes properly. I opened the bottom panel and see the ignition components. The ignitor glows after 20 - 30 seconds...
Your ignitor is going bad...yeah it sounds crazy, but change it and you will be working again...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 17, 2010 | Dryers
My dryer ignites and after a few seconds the flame goes out
hold and assist coils
with model number i could get you the part numbers
Sep 29, 2009 | Maytag Dryers
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Inglis Gas Dryer Does not heat up at all, No spark, no flame
When you start the dryer , after a few seconds do you hear a distinct click sound from inside the bottom of the dryer at the burner assembly? If you do not, you most likely have a bad thermal fuse, part# 3392519 or 3390719, depending on your dryer. Its the same fuse just different shape, both will work. This is most likely your problem. If you do hear a click, you may have a bad ignitor. Best way to test is to check for 120 at the ignitor. If you have anymore questions or need parts feel free to ask in my forum at www.washermd.com, thanks, Dave
Nov 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Oct 14, 2008 | Maytag Dryers
Dryers Logo
156 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
