Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Rheem Fury 42V50-40F. Piezo ignitor will not light the pilot light. A thousand clicks, still won't light. Mfg in 2005. Gas valve is on. Knob set to pilot, red button pushed --- I know how to light a pilot light. Is there air in the line? Is there any trick to this? Thanks!
  • 62 Answers
Sometimes it is necessary to turn the temperature dial all the way back to the coldest setting with the gas valve in the off position in order to reset the safety on some gas water heaters. Give it a try
Posted on Jul 11, 2009
Can't get the pilot light to start
Is this the newer style with closed combustion chamber. If so I would check to make sure that spark ignitor is working. If not it will need replaced. If ignitor is workingthen loosen compression nut on line to pilot and temporarily depress button on gas valve to make sure you have gas at that point.If you have gas there and tighten compression nut to pilot back up and it still won't light then you will need to remove screws that hold cover on burner compartment.Shut off valve to gas supply and remove gas line from gas valve remove pilot and thermocouple lines. Slide burner out ofcompartment and clean it .Remove nut from bottom of pilot assembly and clean out pilot orifice. Blow through pilot line to make sure it's all clear
Reassemble everthing using teflon tape or pipe joint compound as needed.Turn gas supply valve on and check for leaks.Set gas valve control to pilot and depress pilot button and hold. While you are holding button done push spark ignitor every few seconds until it lights. thank you and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light won`t stay burning on my hot water tank. I replaced the thermacoupler;no difference. It is a Rheem Gauardian system ''Fury''. 40 gal in a wellsite skid trailer. Thanks
The thermocouple is a screw in type or 2 wire. You can check the dc MILI volt output with a multimeter. It should probably make 500-750miliVDC when heated. Be sure no plastic from the thermocouple wrapper was on the threads, will not work like that. To light did you push and hold the valve for 30 sec after lighting the pilot then turn to run after the pilot was burning? There is a slight chance the gas valve is bad but not likely. Check the wireing on the thermocouple to the gas valve.
Oct 19, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Kenmore waterheater piezo innotor won't re-light
air in the line, disconnect the pilot supply and hold the button until you smell gas coming from the valve, that will remove the air, as for the igniter, test it by removing the connection and hold it about 1/8" away from the conenction and click it, should see a spark
Sep 16, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot won't light on Rheem Fury G 29-30
Your thermocouple is bad, that's why it won't stay lit. But you are in the right place. The thermocouple is located right in front of the pilot burner. It generaly pulls out and then you follow the copper tubing back to the valve, unscrew the fitting and it will pull out. Go to your local hardware store and purchase one about the same length and install it back in the same order. Good luck.
Apr 13, 2009 | Vanguard International Vanguard BY Rheem...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
1,927 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Donni Steen
Steve Allison
Steve Allison
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
