Question about Philips GoGear HDD1830 MP3 Player
Will not charge
When connected it does not show a charge or that it's connected.
  • 8,596 Answers
Re: will not charge
First, try uninstalling the software that came on the CD,and reinstalling the version of the software on The Philips website.
If that fails:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 19, 2008
0 characters
3 Points
How do you charge the MP620 MP3 Player?
It will show you you it. The screen depends on where you are charging it. If you charge it on a computer it will say connected. When you charge in an outlet it will say charging. If you have more question ask me.
Jul 20, 2014 | Coby MP620 MP3 Player
My Naxa 4GB mp4 player is not connecting with my computer sometimes it does sometimes it doesn't i cant add any new videos or songs because it wont show up on my computer it charges it just doesn't show...
By slowbunny12 on Aug 22, 2010
My Naxa 4GB mp4 player is not connecting with my computer sometimes it does sometimes it doesn't i cant add any new videos or songs because it wont show up on my computer it charges it just doesn't show up.. so what should i do???
Aug 22, 2010 | MP3 & Digital Media Players
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony MP3 & Digital Media Players
Connection and battery charging
Try to turn it off while connected, mine works normally and I can turn it on to use it while connected to the pc cable and then it doesn't communicate with the pc, or charge I think. When I turn it off it goes blank for a moment and then shows the USB symbol and communicates with the computer.
May 28, 2009 | Samsung YP-Z5 MP3 Player
My ipod is showing low battery, but when I connect to charge it, it's not charging....
Your Problem may be the Battery needs to be replaced.
Go here to find one...Click
if you ipod them shows it's it's charging you should be good
Mar 01, 2009 | Apple iPod MA446LL/A MP3 Player
My I pod will not charge or connect to my computer
try a hard reset
hold center button and upper button at same time until apple logo shows, then let go. Maybe that will help
Jan 28, 2009 | Apple iPod nano
Mp4 player not charging up
may the connection is lost contact! use multitester to know if your component have continuity? next is battery if have proper voltage of it?
Jan 17, 2009 | MP3 & Digital Media Players
Ipod does not charge?
i connected my ipod to the computer but it only shows "very little battery do not disconnect"and it does not show the battery sign.please help.
May 11, 2008 | MP3 & Digital Media Players
Philips GoGear HDD1830 MP3 Player Logo
88 people viewed this question
Top Philips MP3 & Digital Media Players Experts
 Mike M
Mike M
Pieter Vleeshouwers
Are you a Philips MP3 and Digital Media Player Expert? Answer questions, earn points and help others
